Manual Tension Conversion...SEARCHED
Old 05-16-2007, 05:03 PM
j.dizzle
Guest
Posts: n/a
Default Manual Tension Conversion...SEARCHED
Found 3 diff sets up part #'s. Also if i already removed my balance shafts do i need....
BRACKET, BALANCER BELT ADJUSTER and ADJUSTER COMP., BALANCER BELT
here are the 3 diff sets of #'s i found
13404-PT0-004 - ADJUSTER COMP., BALANCER BELT
13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER
14510-PT0-004 - ADJUSTER COMP., TIMING BELT
14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER
14521-P14-A00 - PLATE, ADJUSTER
90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE
90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING
90016-PT0-000 - BOLT, TIMING BELT ADJUSTER
90140-P14-A00 - WASHER, PLAIN (11MM)
13404-PT0-004 - balancer belt adjuster
14510-PT0-004 - timing belt adjuster
14516-PT2-000 - adjuster spring
90014-P14-A00 - adjuster base bolt
90015-PT0-000 - adjuster spring bolt
90016-PT0-000 - adjuster bolt
90140-P14-A00 - 11mm washer
14521-P14-A00 - adjuster plate
90501-MB7-610 - washer
90216-P0A-000 - nut
90401-PT0-000 - rubber o-ring
14510-pt0-004 this is the Adjuster, Id suggest a Timken from AutoZone. Its only like 36$ @ honda its 68$. Auto zone can cross refrence the part #'s. The manual tensioner is on the 2.3l.
14516-pt2-000 spring 4.08$
90014-p14-A00 Bolt 3.85$
90015-pt0-000 Bolt 7.15$
900616-pt0-000 Bolt 8.48$
90140-p14-A00 Washer 3.22$
Old 05-16-2007, 05:16 PM
mgags7's Avatar
If you remove the balance shafts, just get some washers to hold the timing belt tensioner pulley down.
All you need is the timing belt tensioner pulley, the bolt it mounts on, the triangle plate, the spring perch, and the tensioner pivot bolt, and then some washers.
Old 05-17-2007, 07:35 AM
j.dizzle
Guest
Posts: n/a
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">If you remove the balance shafts, just get some washers to hold the timing belt tensioner pulley down.
All you need is the timing belt tensioner pulley, the bolt it mounts on, the triangle plate, the spring perch, and the tensioner pivot bolt, and then some washers.</TD></TR></TABLE>
what parts do the washers replace? are the washers from honda?
Old 05-17-2007, 07:39 AM
ericdachampion86's Avatar
Default Re: (swed)
The washers will take up the place where the balance shaft tensioner pulley went. that way the timing tensioner will work.
Old 05-17-2007, 08:28 AM
mgags7's Avatar
No honda doesn't sell washers to do a custom conversion....go to a hardware store.
Old 05-17-2007, 11:11 AM
Mykizism's Avatar
get the damn balance shaft pully from the h23 and use that. dont use stupid wasers from a hardware store.
Old 05-17-2007, 11:28 AM
Maharajamd's Avatar
Just buy the conversion kit from irp...it is like 90 bucks and comes with everything needed.
I just did mine. Pretty easy really.
Old 05-17-2007, 01:09 PM
j.dizzle
Guest
Posts: n/a
Default Re: (Maharajamd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maharajamd &raquo;</TD></TR><TR><TD CLASS="quote">Just buy the conversion kit from irp...it is like 90 bucks and comes with everything needed.
I just did mine. Pretty easy really.</TD></TR></TABLE>
irp? are they on here? anyone else use this kit?
Old 05-17-2007, 04:45 PM
sivikvtec's Avatar
Default Re: (swed)
I just bought that kit too
http://www.importrp.com/produc...age=1
Old 05-17-2007, 05:03 PM
Maharajamd's Avatar
Yea..thats what I got too...
That company was awesome. Cheap, fast shipping, good packaging, and great guys.
Old 05-17-2007, 07:29 PM
mgags7's Avatar
Default Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">get the damn balance shaft pully from the h23 and use that. dont use stupid wasers from a hardware store.</TD></TR></TABLE>
waste of money.
that thing is like $50
Jeffrego
Honda Civic (2001 - 2005)
10-31-2018 05:02 AM
ShortyzKustomz
01-12-2008 09:56 AM
antivic
06-27-2006 12:34 PM
Haleiwa-Brando
03-31-2006 07:10 PM
Jaybird20
06-07-2004 08:37 AM
Quick Reply: Manual Tension Conversion...SEARCHED
