H23 Adjustable cam gear settings...
Hey guys... I was just wondering what adjustments ya'll have found to be most effective for your cam gears. I've got crower stage 1 cams and skunk2 gears, I advanced both gears two degrees and it made a nice mid-high end gain but I'm debating whether to keep screwing with it or leave it alone. It's a daily driver so I'm really not concerned enough to spend the time/money dyno tuning, but thought I would see if anyone had some good results with theirs. Thanks!
Re: H23 Adjustable cam gear settings... (AnthrPludedriver)
take it to a tuner and have them play with it on the dyno. that is the only way to get the most out of it.
Re: H23 Adjustable cam gear settings... (nonvteclude)
Yeah, I figured that but I was wondering what has worked for some other people that I might try. I'm not too worried about maximizing, just to see if I can get anything noticably better than what I've got now. I've heard alot of people advancing the intake and retarding the exhuast, but the local guys told me to advance them both, which worked pretty well. But it's always nice to get a little extra if it's not alot of trouble.
well if your not too worried about it my ignition is retated 3degrees and and intake is advanced 2 degrees
Dont even bother messing with them.....They shouldn't even be installed unless youre planning to tune them on a Dyno. The big thing they do is move your powerband around.
accordexchange
04-03-2003 06:17 PM
adjust, adjustable, adjustment, cam, cams, crower, gear, gears, h22, h22a, h23, h23a, recommended, settings, stage
