M2B4 H22 LSD Transmission Axle Seals? Not Same as Reg.?
Hello, I was curious what the M2B4 JDM H22 Transmission Axle Seals are? tried to replace driver side from normal usdm 95 prelude si vtec h22 model, too small?
Def. not p2u5 or p2a5 either?
Re: M2B4 H22 LSD Transmission Axle Seals? Not Same as Reg.?
You sure you got the right one, OEM? They should be the same, at least for my T2W4 they were and it's a LSD trans too.
The regular 95 si vtec h22 driver side axle seal is too small and appears to be not wide enough as well?
Normal H22 91205-PL3-A01 10 OIL SEAL (35X56X8) (ARAI)
SH Prelude 91201-P6J-003 10 OIL SEAL (44X60X8) (NOK)
I am thinking it's SH one...
Only thing I can think why your Accord one fit is it's an Accord same with the T2T4 F20B trans and F22/F23 and they use the same regular H22 axle seal...
Appears it is the same seal some idiot left the seal of the old one with a newer old one jammed in it and had me wonder wtf.
^Hehe, I knew it was the same, Honda likes to keep things simple, didn't think they would make 1 trans case different than all the other H/F ones for no reason.
patroick67
Transmission & Drivetrain
11
04-09-2012 06:14 PM
