loose timing belt -searched
Old 02-22-2006, 07:54 PM
h22vt's Avatar
Default loose timing belt -searched
i have a 01 prelude that i just put a new motor in (water+cai=bad)and i was having my values adjusted at a different garage than who put the motor in. while they had my cover off they said my timing belt was very loose. so i took it back to the garage that just did my swap and they said it was fine. how loose should it be?
Old 02-22-2006, 09:06 PM
NeriVTEC's Avatar
Default Re: loose timing belt -searched (h22vt)
Just adjust it with the tensioner if it is a manual one.
Old 02-23-2006, 03:31 AM
h22vt's Avatar
thanks but i need to know how loose it needs to be.
Old 02-26-2006, 08:25 AM
b18hondaacura's Avatar
Default Re: (h22vt)
i need to know too.
Old 03-10-2006, 08:36 AM
Do you even PLEBE R8?
ForceFed Motorsports's Avatar
After loosing the acorn nut on the tensioner let the tensioner and spring do all the work... tension should be on the pull side and slack should be on the tensioner side. Do this at TDC... to check you should be able to bend the timing belt 90 degrees so that it is facing you with your fingers. If its really easy or goes past that its to loose. If its ridiculously hard then its to tight.
Timing belts can be a pain but for a honda its all in the tensioner so you shouldnt have to do anythin major for adjustment.
Old 03-10-2006, 09:46 AM
98TypeSH's Avatar
Default Re: loose timing belt -searched (ForceFed_Motorsports)
what type of motor was put in ? JDM ? USDM ? eaither way, it has an auto tensioner. Maybe you should replace it before it takes a fat **** on you. Manual conversion or buy a new auto.
soodominican
10-12-2008 08:59 PM
h22mark
04-25-2007 07:44 AM
Greg123
03-18-2003 05:59 PM
johnzm
06-16-2002 06:56 PM
KoRE
06-15-2002 09:27 AM
Quick Reply: loose timing belt -searched
