Daytime running lights, gauge cluster lights, and running brake lights>>not working
my daytime lights ( side markers....ect) and guage cluster lights, running tail lights are not functioning ( break lights work when break is applied). the lights were working all day until i purchased a Cobra Radar Detector. when i plugged it into the ac/dc port. everything was working fine... i went to the gas station to get gas, turned car off, got gas and when i started the car is when the problem erupted can anyone help. i just got done getting new fuses installed from pep boys. still not working...anyone ??
Re: Daytime running lights, gauge cluster lights, and running brake lights>>not worki
Fuses pop when there is a fault in the circuit. Like a wire thats insulation has worn off and is grounding or shorting to metal for example. Find the fault, the fuse will stop blowing.
I would also look into a faulty ground connection, maybe look into the wiring schematics and see if some of those circuits have a common ground
jobe_149
02-11-2005 08:31 PM
shaferz
02-29-2004 07:19 PM
