just installed my act clutch
New User
at first i drove the car the clutch pedal felt squishy and stuff like the liquid in the master cylinder is low, so then i drive along later and my clutch pedal fell right to the floor? so i got down and pulled back up the clutch pedal and then it was fine like how it is to be, what could be the problem? did the problem fix it self?
Re: just installed my act clutch (vpforeva)
So what you are saying is that your clutch works now? If it does it again, you may want to check your master cyclinder or your slave cyclinder next time. Those usually tend to go out.
hey the same thing happened to me...only the pedal didnt come back up to the normal position.
check your slave cylinder...that is what was wrong with mine.
skhell
Transmission & Drivetrain
06-23-2010 12:11 AM
FLCivic
06-30-2004 03:48 PM
