jerky acceleration
Old 09-26-2007, 08:17 AM
tuffghst's Avatar
Default jerky acceleration
97 prelude base
AEM intake, greddy exhaust
I get jerky acceleration/loss of power every once in a while, seems to happen only on a cold engine/cooler days. Almost a choking/struggling feeling. Only happens for a minute or 2 after startup. Any ideas? EGR?
Old 09-26-2007, 08:41 AM
moderator emeritus
98vtec's Avatar
Default Re: jerky acceleration (tuffghst)
how long has it been since you changed the fuel filter?
Old 09-26-2007, 08:51 AM
tuffghst's Avatar
I've owned the car for 2 weeks...i don't know when it was last changed. Probably a good place to start?
Old 09-26-2007, 08:58 AM
moderator emeritus
98vtec's Avatar
Default Re: (tuffghst)
i would do that and spark plugs/wires. Might as well change the oil and oil filter along with a distributor cap and rotor.
that just me tho. Would rather change it all now and know everything is new.
Old 09-26-2007, 09:52 AM
Ralleh's Avatar
I was going to replace the fuel filter for my 97 base as well as I was getting something similar occasionally, but I was told that Fram filters suck and I should stick with the OEM parts. Is there a difference?
Old 09-26-2007, 12:41 PM
JDMhondalude22's Avatar
Default Re: (Ralleh)
are you letting the car get to operating temp? vtec wont work unless its warmed up.... just a thought.
Old 10-15-2007, 01:46 PM
tuffghst's Avatar
bumping this back up.
I replaced the air filter, fuel filter, plugs, wires, distrib cap/rotor...all with top quality stuff.
Still seem to have the same problem. Temp doesn't seem to matter as i originally thought and it happens out of vtec. Still get a choking/struggling feeling that lasts sometimes a couple seconds and sometimes a minute or 2. Not sure what my next step should be.
Old 10-27-2007, 10:07 AM
Kiojoe's Avatar
Fuel pressure regulator or fuel pump?
Collapsed or collapsing fuel line.
KJ
Old 10-27-2007, 03:44 PM
prelude_93vtec's Avatar
is the car auto or manual? ive heard problems like that with autos. it might also be the Im clogged up. try seafoam
Old 10-27-2007, 04:44 PM
KAZZ_786's Avatar
Default Re: jerky acceleration (prelude_93vtec)
does it happen between 2500 and 3k revs? if so it might be the EGR or EGR manifold that is blocked a bit. that is what was wrong with my 97. had it cleaned out and prob gone.
Old 10-27-2007, 05:04 PM
tuffghst's Avatar
Default Re: jerky acceleration (KAZZ_786)
its manual.
it does seem to happen at lower rpms...after the initial struggling it will then "launch" or lurch/kick ahead to normal acceleration. I've read up on EGR and it seems to have the right symptoms.
Old 10-28-2007, 06:08 AM
Kiojoe's Avatar
tuffghst can you email me?
I would like to talk to you about your car for sale.
but being noob I can't email you here or reply to sell threads.
gojoe6869 on yhoo
I don't know any other way to do it.
KJ
Old 10-28-2007, 01:32 PM
royalfelix's Avatar
hey i have a 92 prelude auto h23a1 and i have the same exact problem... and i still dont know what it is so if you find out please let me know!!! i cleaned out my egr and the valve works fine... and i still have the problem...
Old 10-31-2007, 08:21 AM
royalfelix's Avatar
anyone know the problem???
Old 10-31-2007, 12:40 PM
tuffghst's Avatar
i'm taking it to the honda dealer on friday
Old 10-31-2007, 01:12 PM
androO's Avatar
thats funny i have the same exact set up. AEM + Greddy exhuast and sometimes I feel it choking as well. i'm going to to do a major tune up this saturday. replace all belts, spark plugs, fluids, waterpump, thermostat, etc.
i'll see if it helps.
Old 10-31-2007, 01:13 PM
androO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuffghst &raquo;</TD></TR><TR><TD CLASS="quote">i'm taking it to the honda dealer on friday</TD></TR></TABLE>
let us know what you find out on Friday
Old 10-31-2007, 01:16 PM
androO's Avatar
what type of gas are you putting in it? 91 octane always.
Old 10-31-2007, 02:18 PM
tuffghst's Avatar
always the best i can get
Old 10-31-2007, 02:27 PM
Quade's Avatar
My car is a 92 vtec and it feels very choky at times too. I believe the stock exhaust has some kinda restriction. Can't wait to change it. Is your exhaust stock as well?
Old 10-31-2007, 02:44 PM
LukieLuc's Avatar
Default Re: (Quade)
My car does the same thing but mostly up hills, mostly, i found out that it was IABs stuck open, not enough air resistance to help with tq down low
Old 11-01-2007, 06:15 AM
mgags7's Avatar
Default Re: (LukieLuc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">My car does the same thing but mostly up hills, mostly, i found out that it was IABs stuck open, not enough air resistance to help with tq down low</TD></TR></TABLE>
oh its air resistance, huh?
Old 11-01-2007, 06:45 AM
prelude_h22vtec's Avatar
IABs do not make a noticeable difference
Old 11-01-2007, 06:27 PM
royalfelix's Avatar
my car only does it when i turn it on some tyimes the first 5 min i drive the car will bogg i will push the gas a lil more couple times and the check engine light comes on and the problem goes away. but since my car is a 92 i cant check the codes my self can i??? some how???
Old 11-03-2007, 03:11 PM
royalfelix's Avatar
so.... what did the deal say...???
Quick Reply: jerky acceleration
