JDM H23A Vtec Blue Top Mystery Motor, True Facts, Questions? - Page 43 - Honda-Tech
Old 12-17-2016, 08:04 PM   #1051
nus_dogg's Avatar
Default Re: JDM H23A Vtec Blue Top Mystery Motor, True Facts, Questions?
Quote:
Originally Posted by ESP.net View Post
X2 go with the healthier engine. Difference between PDE 00-01 and Non is PDE has 45 degree valve seat instead of a 60 normal h22. It also has slightly smoother casting in the intake runner. As well as the intake manifold gasket port nose are is a little bit more open and gasket matched. Due to has similar bottom intake/gasket as PDE Euro R.
Is this why the Type S cams eats up the normal H22 rocker pads? It's been a min, just trying to refresh my memories.
nus_dogg is offline   Reply With Quote
Old 12-18-2016, 08:26 AM   #1052
Quote:
Originally Posted by autoluder View Post
Aradin, good insights..
I think i still use the IABs for the low speed corners where i may fall out of vtec but dont want to downshift. And dont want to lose any lowend torque. But it would be nice to have a simpler set up and less parts to wear out or break, I always think about that IAB vacuum box and how i would ever replace it. My H23A came with the ports busted, i was hoping to have a back up. I may look into a Euro-R manifold, seems to be good middle ground. But the spacer like you said may be the easiest and fastest solution, i remember blacktrax selling these parts. Thanks reminding me! :-)
No problem. I would be willing to bet that you would see more torque under the curve and improved peak horsepower without IABs on the H23A versus your previous setup. The blue top's 95mm stroke makes an exceptional amount of low end/midrange torque.
Quote:
That's a good question. I think that's the general consensus but it makes me wonder, what about the F20B? The PCB heads they come with seem to be based on the older P13 castings. As we know, the manual versions come with Type-S cams yet they didn't suffer from that issue.
Aradin is offline   Reply With Quote
Old 12-28-2016, 01:33 AM   #1053
In H23 VTEC oil squirters are not necessary. There are grooves in bigger rod end that work like oil squirters and spray oil on the bottom of the pistons.
I wanted to install oil squirters in my H23A but it was impossible to bend them that they clear the pistons and crank.
h1tman is offline   Reply With Quote
Old 01-06-2017, 11:49 AM   #1054
ESP.net's Avatar
PCB F20B has there own heads... Could be 60 degrees as well.... I think the rocker wear was more of an issue with those trying to use stock P13 valve springs with TypeS/EuroR cams... Valves not being percisely in sync needing a stiffer spring with higher lift cam. But yes I think it was more common on the OBD1 motors with non behive LMAs
ESP.net is offline   Reply With Quote
Old 01-18-2017, 06:34 AM   #1055
Former Moderator
B18C5-EH2's Avatar
Tried looking through some pages of this thread, but figured someone could tell me more quickly. Are the H23A blue tops using the FRM lined cylinder walls like the 00-spec H22A found in USDM Preludes? Google searches yielded different results.
B18C5-EH2 is offline   Reply With Quote
Old 01-18-2017, 07:11 AM   #1056
Moderator
snobordboy's Avatar
Quote:
Yes.
snobordboy is offline   Reply With Quote
Old 01-19-2017, 04:56 AM   #1057
1funryd's Avatar
Again....(sigh) All H motors are FRM sleeved.
Only F series motors have iron sleeves(minus the F20c - S2000 motor which does not apply here anyways)
1funryd is offline   Reply With Quote
Old 02-24-2017, 10:00 PM   #1058
Go Tigers!
Bense's Avatar
What piston rings do these bad boys use?
H22A4?
Bense is online now   Reply With Quote
Old 02-25-2017, 02:57 AM   #1059
All 97- H's use the same piston rings. I think.
H22A4-H22A8 and Type S/R have the same piston ring part number
TimiK is offline   Reply With Quote
Old 02-27-2017, 10:59 AM   #1060
ESP.net's Avatar
True should be no difference than H22 and ANY H23 on piston rings
Old 03-16-2017, 11:34 AM   #1061
^Sammy]!.'s Avatar
Location: 9/11/01 WTC Never Forget, United States Of America
If someone wouldn't mind answering this question
H22 IACV will work on H23A Intake Manifold with Rosko IACV adapter?
^Sammy]!. is offline   Reply With Quote
Old 03-17-2017, 11:45 AM   #1062
ESP.net's Avatar
It should that is what Rosko made the kit for Euro R 3 wire IACV to H22 IACV 2 wire... one bolt lines up other does not... thus need bracket.
Your better off getting the IACV relocation kit if firewall is close and or not a lot of room up front
Old 03-20-2017, 06:57 AM   #1063
^Sammy]!.'s Avatar
Thank you ESP.net
Old 03-22-2017, 07:42 AM   #1064
^Sammy]!.'s Avatar
Could someone with a EK H2B swap running stock IM measure the clearance between that and firewall please.
Thank you
Old 03-23-2017, 04:47 AM   #1065
Moderator
snobordboy's Avatar
Thank you
Might have better luck in the hybrids/ engine swaps section with that question!
Old 03-24-2017, 12:07 PM   #1066
ESP.net's Avatar
Those that are Straight H going to need one of these for the Lower K series intake manifolds. OEM Rear T Bracket wont work. It is also Slimmer, Stronger and Easier install. Installs only on driver side. This is not a for sale post do not ask how much.. PM with any question. Pictured is a K2H Excessive Intake manifold
Old 03-27-2017, 06:30 AM   #1067
Moderator
snobordboy's Avatar
John,
Can you post pictures of the clearance issues with the stock rear mount and the K manifolds, I assume RBC is the one you are referencing?
I don't see how this affects the H23 any more than any other Vtec H-series engine, but keep it tech enough and I will be ok with it.
Old 03-27-2017, 11:48 AM   #1068
ESP.net's Avatar
Quote:
Originally Posted by snobordboy View Post
John,
Yes believe on the H swap with RBC it hits... With Excessive Mani as well which is even lower Hits a lot... Pictured is a K Excessive with 80mm TB... thought I would answer this instead of later... believe it hits the top of the OEM Rear T Bracket.
WTB: H22 Type-S/Euro-R parts Katman Want to Buy 6 10-15-2016 05:49 PM
Euro-R (PDE) vs. Stock (P13) cylinder head comparison (pics) cpmike Honda Prelude 34 08-11-2015 02:04 PM
where can i buy a JDM H23 vtec? loya15 Honda Accord (1990 - 2002) 2 07-13-2015 05:09 PM
Interesting...Blue Top H23A beware:(pic intensive) precord96 All Motor / Naturally Aspirated 65 02-28-2011 07:34 AM
H23AVtec Blue Top 97mm Stroke All Motor Build Questions for H guru's ESP.net All Motor / Naturally Aspirated 2 07-10-2010 09:31 AM
Tags
2000, arp, blue, bluetop, bolt, dohc, h23, h23a, harness, head, jdm, rod, top, torque, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
