JDM H23A Vtec Blue Top Mystery Motor, True Facts, Questions?
#76
Re: (alterdcreations)
FRM cylinders... I'll post up the measurements today try a lil harder with my tool. But it does appear that they are infact very similar to the JDM H22A cams within a couple thousandths... which would make me think reason is off is me or wear and it's too close and they are the same...
#78
Re: (Televator)
I did 2 vtec lobes on each side Intake and Exhaust: JDM H23A Vtec Blue Top:
These are as acurate as I can get with cam tops on... there maybe a couple thousandths difference at most...
Intake:
1.452 36.88mm
1.451 36.86mm
Exhaust:
1.427 36.25mm
1.427 36.25mm
I couldn't see too much of a difference in slopes but really didnt take that good of a look. I don't have my JDM H22 Cams anymore sold them last night with my old engine that went. so did a half as measurement last night...
Pirate maybe able to determine on the measurements above
Modified by ESP.net at 10:47 AM 7/23/2008
Intake:
1.452 36.88mm
1.451 36.86mm
Exhaust:
1.427 36.25mm
1.427 36.25mm
#79
Re: (PirateMcFred)
Agreed... these cams do look more like the US spec NoN SH... wish I would of kept my half *** numbers off my jdm h22 vtec but they did appear to be the same...
US spec 97-01 Type SH even has a lil better cam:
Pirate and Natalie... see any issues of me running Type S cams on the stock valve springs and retainers...? I read a while back some people had rocker issues? Because they didnt switch out to Type S springs and retainers? was this definetly a 97 and pre head issue? Thanks for the help guys.
I believe it was how the PDE Euro Head valve angle difference? Well if this head is a PDE like it is does this mean I shouldn't have an issue?
Modified by ESP.net at 11:38 AM 7/23/2008
#81
Re: (ESP.net)
Final Tally of the In's and Out's of this Auto H23A Vtec 2000 Blue Top:
* 55mm mains
* No oil squirters
* factory balancing holes on crank seems to be same as H23A1
* PDE-3 rods that have a threaded in bolt into Rod with no nut
* PDE head HF-1 (Same as Euro R/ Type S)
* 65.5mm Throttle Body tappers to 62mm on inside (Same as Euro R/ Type S)
* Markings on Throttle Body read PCBX HF-1
* PCB top part Timing Belt Plastic
* P13 bottom part Timing Belt Plastic
* P13/JDM H22A water pump
* P13 Timing Belt part #
* Hydralic Tensioner
* Alternator ONLY crank pulley (Most like same part # as F20B, Euro R)
* Cams from measuring seem to be USDM/JDM H22A cams
* FRM cylinders
* Pistons most likely is similar to the USDM H22A piston but with H23 like valve reliefs
* Intake manifold looks more so like a smaller stock Accord one then a H22A
* Obviously has secondaries like a USDM/JDM/Type S manifold
* Euro R/Type S style injectors and possibly angle
Modified by ESP.net at 1:38 PM 7/23/2008
* 55mm mains
* No oil squirters
* FRM cylinders
#83
Re: (vinuneuro)
Yea I'll actually take off the intake manifold here in a few minutes, and compare the head to the usdm one I happen to have... I'll post pictures up...
#85
Re: (Televator)
Here are the Intake Manifolds side by side H23A Vtec on Left and JDM H22A on Right: It does seem the nose of the port on the H23A Vtec manifold is different possibly lil smaller then the normal H22A manifold which could be from the Euro R/Type S style injector and angle?
Close up of JDM H22A intake manifold:
Close up of the H23A Vtec intake manifold:
Normal H22A Intake Port:
H23A Vtec Intake Port:
I cleaned both the Intake ports, The H22A head seemed to have a lot more rougher casting with a kinda big dip as the runner goes down. The H23A Vtec Blue Top seemed to have a definetly noticable smoother type casting with no dips. The pictures aren't the best quality. It kinda seemed like on the H23A Vtec intake port there was a lighter and darker area as to where the sandscroll etc. might of stopped but this is just an assumption. Better casting or a Factory Port??? Duno I personally never seen a Type S or Euro R or Type R factory job...
#86
Re: (ESP.net)
The "R" spec PDE head I have has an inch-long blue paint mark down the front.
The US base PDE head I have doesn't. Never seen the inside of either though. It would be interesting to.
#90
Re: (vinuneuro)
The ports seem to be the same it's part coming from the top of the circle to the nose area that seems a lil smaller/different then the H22A traditional I will take the gasket off the Blue Top and put it on the H22A traidional items tomorrow.
#91
Re: (ESP.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net »</TD></TR><TR><TD CLASS="quote">The ports seem to be the same it's part coming from the top of the circle to the nose area that seems a lil smaller/different then the H22A traditional I will take the gasket off the Blue Top and put it on the H22A traidional items tomorrow.</TD></TR></TABLE>
I would say that has to do with the injectors like you said as well. I had no idea this was the same head as the Euro-R. I've been thinking of getting one of these from H-Motors.
#93
Re: (Rosko)
I think I am just going to run the cams that are in it and see what kinda #'s we get....
I really dont want to take the investment of $450 on Type S cams and find out I have an issue with the valve springs like Pirate explained. Definetly do not want to take the head off at this time to replace valve springs/retainers and valve job.
#94
Re: (ESP.net)
Thought I would toss this into the thread. I got the Blue Top H23A Vtec dyno tuned today by James at http://www.SpeedFactoryRacing.net I was pretty pleased with the results.
212 whp 174 ft lbs torque.... his dynapack is meant to be more accurate then a dynojet and has dyno sheet comparisons saying his dynapack reads lower. Est. whp on dynojet is 225 range.
Mods again:
ESP 4-2-1 Header 2.5" collector
3" quick dump off with magnaflow round muffler
OBD1 H22A injectors 345cc
Manual Tensioner
Euro R manifold
68mm TB
3" short ram BPI stack K&N filer
Stock H23A Vtec Blue Top CAMS
p28 chrome tuned
Vtec 4600 RPM
Mods again:
Manual Tensioner
Euro R manifold
68mm TB
p28 chrome tuned
Vtec 4600 RPM
#96
Re: (vinuneuro)
His dynapack is meant to read lower then a dynojet, dynojet would of gained me higher numbers... fact not fiction
He has sheets and comparisons of a few cars on his dynapack and a dynojet. His dynapack sees lower #'s
Pro 1 JDM H22A with bolts on that dyno has seen mid to low 190's whp and 150+ trq. He has a sheet on file as well.
After dialing in AFR's right off the bat on first run was 202 whp with no dialing of timing. Then we played around.
#97
Damn, This whole thread is chock full of info concerning the h23a vtec!
Im amazed at the power it puts out with such minor mods!
I need to get me one of these god-like motors.
#100
Re: (mmmtrbolude93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmmtrbolude93 »</TD></TR><TR><TD CLASS="quote">does anyone know whether an exhaust mani from an h22a1 will bolt up to a h23 bluetop vtec?</TD></TR></TABLE>
it will, he's running his H22 ESP header.
