Possible rear damage?
Old 10-10-2008, 11:38 PM
Stykz's Avatar
Default Possible rear damage?
Alright, so I got a little retarded the other night, came around a corner too hot, and slid sideways into a curb. Probably doing about 20-25mph, front tire hit first, swinging the rear into the curb. It didn't hop onto the curb or anything, just kind of bounced off. Scratched the **** out of my rims. Now, it is driving normal, and handling normal, but the rear tire has been making a low tone, kind of like a train coming down the tracks. I keep thinking I might have a flat tire, but I get out and it's fine. I've pulled both tires off, and all of my suspension looks fine.
Does anybody know what could be making this sound? Possibly out of balance? It's a 1993 Prelude Si
Old 10-11-2008, 12:51 AM
no1knows908's Avatar
Default Re: Possible rear damage? (Stykz)
I would have at least that wheel rebalanced then have a 4 wheel alignment. If the sound persists, I'd check the wheel bearing.
Old 10-12-2008, 10:37 AM
TheWalrus's Avatar
most likely a bent rim causing the tire to hop a bit. wheel bearing is tough, rim and tire took most of the beating. a shifted belt in the tire could also make noise, but not likely...get it rebalanced and theyll tell you whats up
Old 10-12-2008, 06:01 PM
Kronn 98SH's Avatar
Default Re: (TheWalrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWalrus &raquo;</TD></TR><TR><TD CLASS="quote">most likely a bent rim causing the tire to hop a bit. wheel bearing is tough, rim and tire took most of the beating. a shifted belt in the tire could also make noise, but not likely...get it rebalanced and theyll tell you whats up</TD></TR></TABLE>
I was also thinking bent rim.
Old 10-13-2008, 06:57 PM
twiztid00002's Avatar
Old 10-13-2008, 07:31 PM
PyroDK1's Avatar
Default Re: Possible rear damage? (no1knows908)
my guess is its prob a wheel bearing.
Old 10-14-2008, 12:07 AM
Stykz's Avatar
Alright so I took it in. It was all sorts of unaligned. Everything was aligned, balanced, and rotated. Still making the churning sound, which I myself am pretty sure it's the bearing as well. My Caster is still way off, my driver side is 3.0 while the passenger side is -1.2 They weren't able to fix that, so now driving my car is like trying to land a plane in strong crosswinds.
Old 10-16-2008, 09:01 PM
TheWalrus's Avatar
replace the radius rod on that side and check out the subframe where it connects, also check the UCA. those are the parts that change caster
4everVtec
03-19-2017 09:11 AM
rollercosta123
09-03-2006 04:23 PM
mikeunreal2
03-01-2006 02:21 PM
Ideal
10-29-2005 06:34 PM
The Flying Dutchmen
07-29-2005 07:56 AM
Quick Reply: Possible rear damage?
