imobolizer ?
Re: imobolizer ? (darkvader)
How did you screw it up? Have you tired reseting your ECU? Disconnect your negative battery wire for awhile, then see what happens
New User
dam car won't start its trying to start and it wont start ?
I'm still not 100% sure what you are trying to ask. But if the car is cranking, but not starting, then you can rule out the Immobilizer as an issue. The Immobilizer interrupts the starter. So if it was really an Immobilzer problem, you would not be able to crank the car.
I hope this information is relevant to whatever it was that you were trying to ask.
Andrew
Re: imobolizer ? (Mykizism)
while we are on the subject.. i just got my prelude and i want to know what the immobilzier system does or how does it work?
Don't tell anyone, or else every honda and acura will be stolen keep it on the DL.
