Immobilizer and the RED key HELP
Hey guys, first time poster long time lurker.
To get right to it, I own a 2000 prelude with a 96 JDM crate H22A motor in it. Everything was converted to OBD1 but since we left the existing harness in just ended up using a a OBD2-obd1 conversion harness which is hooked up to a chipped p28 but I also have a chipped p72 too.
That's just a little about my car. Now the issue. The last day of my build, and 30 hours working on it, I decided to tune the ECU on my laptop. Everything went smooth so I called it a night and went to bed. The next morning I woke up and was unable to find my keys. They literally disappeared into the void but I remembered I had the "RED" key. So I used that to open my doors to look inside. Incase I locked my keys in the car. .... Couldn't find them. So I'm freaking out. I recall that you are not suppose to use the "RED" key in the ignition because I have some clue of what it does. So first I disconnect the 2 plugs off the immobilizer and then tried to crank it.
Nothing happened. No I got the idea to get a blank, non-transponder copy of it and I hooked the immobilizer back up. At this point I tried cranking with it hooked up, nothing happened, then I tried with it disconnected, nothing happened.
Now when I say cranking I mean, trying to start the car but every time I start the car everything goes dead I don't even hear the starter relay trying to click
Now I'm running out of options. I call My club member at Honda and he texts me the immobilizer brake code for my car. So I then try that with the blank. Nothing happens.
On top of that I'm not even getting a green blinking key light when I use the non chipped key..... So WHAT HAPPENEDED TO MY BLINKING LIGHT?? Everything else kicks on like my ECU light, that then goes away like normal and my fuel pump kicks on. But when I turn the key I do no even get a crank. Everything cuts off. My Volt gauge reads 12 on ACC position but when I try to cran, all of the lights turn off and it drops to 0.
Basically the moral of this story, and thanks for reading all the way through, is that I'm lost.
What can I do to bypass this thing?
Why am I not getting a green key light when I turn the ignition?
Why isn't my starter working?
Is there a non cost way to bypass?
Can the red key **** up my ECU?
I heard of someone bypassing the immobilizer with a s2k push start. Is this true? And if so how? I do have a eBay push start I could use.
Any answers would be appreciated. Thanks!
Re: Immobilizer and the RED key HELP
Even though you're using a non immobilizer ecu the immobilizer unit in the ignition still works so if you don't have the key it won't crank.
You basically need to have the car towed to a dealership and have them reflash you new keys. Or find your old ones.
The 97-01 Prelude's have an immobilizer system that includes the chipped key, ignition ring, ECU's immobilizer, and IMMOBILIZER CONTROL UNIT.
You've already bypassed the ECU immobilizer by installing the OBD1 ECU, but you still need to bypass the Immobilizer control unit for the starter to work: 97-01 Honda Prelude Starter Bypass Information
