Ignition switch???
Ignition switch???
Ok, my Meter fuse keeps blowing which knocks my whole dashboard out. The Helms says from the 10amp fuse that keeps blowing and from the battery there are only 2 other fuses underdash and the ignition switch. Now I know the 2 fuses are good, so that only leaves me with the ignition switch. Is there a way that it could have gone bad and is grounding out which is blowing my fuse? I'm going to try and find out tomorrow but i thought i would ask if anyone else knows anything about it. Thanks
Re: Ignition switch??? (Fly1865)
Quick question, do you have an aftermarket stereo?
Just curious because there is an illumination wire behind there
and if it's exposed and it touches metal it will blow your fuse
and cause the cluster lights to go out. This happened to me and
that's what caused it. Just an idea though
