F22a to H23 already searched no answer
Ok so i have searched all over this damn forum. Theres swap info for h23-h22 f22-h22 but there isn't much about f22a-h23. All i need to no is what do i need for the swap. Do i need the h23 ecu for it or can i just use the F22? I kinda already no u need the h23 ecu but i need a def answer. Also u can use the f22a trans on the h23 find right? Would i need anything else for it? Clutch, axles anything. I really need this swap to be cheap. i am selling the car soon but the stock motor is going bad. I have found a good deal on a h23, but i wana no what i need. PLEASE HELP ASAP Car has a new owner but we need this fixed before it is finnal. Thanks for any help.
Re: F22a to H23 already searched no answer (Coldth1)
yes you can swap very easily. assuming your f22 is obd1. you didn't clarify if it is a lude or accord. the f22 ecu will probably run it, but h23 ecu is recommended. everything will bolt up (ie trans, axles, clutch....) may need to add knock and IAB wires i believe. depends on if it is a f22a4 on the IAB. good luck.
