I need a half/mid/intermediate shaft for my H22, what else would fit?
Does anyone know if a 90-93 accord shaft would work?
I've heard that 94-97 Accord shaft works. Any others?
Re: I need a half/mid/intermediate shaft for my H22, what else would fit? (Daily Interlude)
i dont know if h23 half shaft would work, but i have a spare one.
It depends on what CV axles you're using. If you have H22 CV axles then you need to stick with an H22 halfshaft. If you have F series CV axles then you need to use an Accord or F22 Prelude halfshaft. I don't know about H23's.
Modified by 2lude4u at 12:35 PM 3/6/2006
Last edited by tech8; 10-02-2020 at 06:50 PM. Reason: This is not the marketplace.
I thought all these axles where interchangeable?
I'm currently using Accord inner CV's on the passenger side.
I need both the axle and mid shaft so if they need to be paired together, then that's what I'll need...
Re: (Daily Interlude)
as far as i know the h22 and h23 axles are interchangable, atleast i reused mine for my h22 swap. i do believe there is a difference in mounting points for the base model and sh on the 5th gen? but i have a spare halfshaft if you want it.
Re: (pentaq)
like stated above you have to use whatever axels your half-shaft is from. If it's an Accord half, then accord axels ,if its a lude half then lude axels. Either shaft will bolt up to the H22 block just fine. 90-93 Accord axels are a bit shorter than lude axels. Go with 94-97 Accord they are the same.
(I have a 91 Accord with an H22 swap)
Thanks everyone, just want to make sure that when I tell people how to build their axles for the 3rd gen lude H22 swap, that I'm giving them good information...
hamgumball
08-10-2004 11:36 PM
