How to use inductive timing light?? HELP - Honda-Tech
Old 12-30-2005, 06:19 PM   #1
bb4socal's Avatar
Default How to use inductive timing light?? HELP
Ok guys. trying to do the ignition timing. I bought a tming light, but i dont knwo how to use it. I understand the connecting part, but how do i use it? It doesnt have any ***** to change anything on it. SO do i just point into the whole and connect the lines into the V shaped metal piece in the tranny housing?
Its a basic timing light, just a gun like wiht a trigger. So what do i do guys?
bb4socal is offline   Reply With Quote
Old 12-30-2005, 06:53 PM   #2
Default Re: How to use inductive timing light?? HELP (bb4socal)
thats it! one side to positive, one side to negative. the other lead to #1 spark plug wire, aim, and shoot!
onefastrx7turbo is offline   Reply With Quote
Old 12-30-2005, 08:05 PM   #3
Rosko's Avatar
Default Re: How to use inductive timing light?? HELP (onefastrx7turbo)
Rosko is offline   Reply With Quote
Old 12-30-2005, 08:17 PM   #4
bb4socal's Avatar
Default Re: How to use inductive timing light?? HELP (Rosko)
thanks guys
I have an issue...the car is ideling at about 1k at normal opt temp. I cant get the idel screw to move. It seems to be a bit tight, and i cant get a flat head to stay in the groove. What should i do about that?
So i adjusted the ign. timing at 1k rpm. Is that okay? SO i pointed the hun into the lil hole and there was line, then a 15, then a line. So what i did was pput the 15 inbetween the "V". IS that all?
Im running a cell light, because i have no 02 sensor hoooked up. I dont have the h22 downpipe. Is it ok to adjust timing with CEL light? And i just hook up a 02 sensor o the plug, just hanging there to turn the cel off? Just temporary till i get the downpipe. Let me know guys.. Thanks for all your help too!!
Rear running lights not working William Reklaw Honda Civic / Del Sol (1992 - 2000) 2 11-06-2016 05:41 PM
4th gen. bumper light stays on after signaling. wtfitzphat Honda Prelude 2 09-18-2008 04:53 PM
wiring F20B ludecrasy87 Honda Accord (1990 - 2002) 1 01-05-2007 04:14 PM
How do i connect two wire....(butt connect) .water Audio / Security / Video 24 12-18-2005 01:23 AM
connecting the City lights Giga Crusher Honda Civic / Del Sol (1992 - 2000) 3 04-25-2005 11:37 PM
Tags
2005, 93, civic, gun, h22a, honda, hook, hookup, ign, inductive, light, rx7, set, si, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
