How To Set H22A1 Timing Belt? - Honda-Tech
Old 11-12-2010, 06:54 PM   #1
serjey15's Avatar
Default How To Set H22A1 Timing Belt?
Hey guys, so I tried searching couldnt find any help.
So pretty much Im trying to replace my timing belt on my H22a1, and I heard that these have an automatic tensioner, and that you need a special tool to losen it or something.
Does anyone know about this?
Also does anyone have a guide or picture on how to set it and is it possible to change thee TB without the "special tool"? thanks.
serjey15 is offline   Reply With Quote
Old 11-12-2010, 07:31 PM   #2
Default Re: How To Set H22A1 Timing Belt?
I'll look it up on alldata. You can rent most "special tools" from autozone.
My GFs jetta manual said you needed a "special tool at the dealership" to change the headlight bulbs. That special tool- your bare hand.
kmcormick9 is offline   Reply With Quote
Old 11-12-2010, 07:37 PM   #3
No special tool needed. I can email you a PDF of the whole job if you want.
Old 11-12-2010, 08:42 PM   #4
the171's Avatar
you are supposed to use a special tool. The auto tensioner is a hydraulic unit and quite powerful. You are to remove it from the engine, then remove a service bolt out of the tensioner. You then insert a small screw driver into the service hole and turn to compress the tensioner. Sounds simple enough, but getting the service bolt back in the tensioner and then getting the unit back on the motor without having the tensioner rebounding on you is very challenging. It is also full of hydraulic oil so you have to try not to spill any while fiddling with the thing. The purpose of the special tool is to keep the tensioner in compressed mode while you work. I have done it a ghetto way, using a hose clamp.
Many will tell you the auto tensioner can fail causing engine damage. The H23A engine came with a manual adjuster kit that can be used on the H22 which is waaaay more simple and safe to use. I now use this and recommend it. You can but the kit with new honda parts for under $100.
the171 is offline   Reply With Quote
Old 11-12-2010, 10:27 PM   #5
serjey15's Avatar
Quote:
That woould be fantastic bro please do/
serjeycbr@hotmail.com
Old 11-13-2010, 03:59 PM   #6
^Just go on spoonertuner(dot)com and get the helms manual, thought everyone knew about it being hosted there.
minilogoguy18 is offline   Reply With Quote
Old 11-13-2010, 10:49 PM   #7
gstrudler's Avatar
I'm sure it could be done without the tool, but it would be quite difficult. You have to keep the auto tensioner locked in place while setting the timing belt, and then you pull the tool out once everything is installed and you've verified everything is at TDC. It basically looks like a big 'C' bracket (but with straight sides) that goes around the tensioner. I believe Honda no longer sells these on their own; they only come with the kit, but I would check with your local dealership to be sure; they are only around $15 and well worth it if you can get it and want to re-use your tensioner. Of course, if you are replacing your t-belt, you should be replacing the tensioner as well. The auto tensioner was also updated, so if you are running a stock VT, the newer tensioners should work fine without any reliability issues.
gstrudler is offline   Reply With Quote
Old 12-10-2010, 04:15 PM   #8
can you email me it PLEASE miamylove2007@yahoo.com
Steve and Nikki is offline   Reply With Quote
Old 12-27-2010, 02:53 PM   #9
Thanks every1 I went the way of a manual timing conversion kit. it was very easy !!!!!!!
Old 12-27-2010, 08:01 PM   #10
serjey15's Avatar
Yeah I converted to manual tensioner too, no problems at all very reliable.
Old 12-28-2010, 06:39 AM   #11
i have a prelude that has an auto tensioner from japan.(h22a) do i need to change it to manual tensioner.
mjolson is offline   Reply With Quote
Old 12-29-2010, 11:45 AM   #12
flyrod's Avatar
special tool for autotensioner = zip tie
flyrod is offline   Reply With Quote
Old 06-23-2011, 01:28 PM   #13
did anyone have any valve problems? I have an H22A1 and people keep saying I probably ****ed my valves
preludelovr96 is offline   Reply With Quote
Old 06-24-2011, 06:34 AM   #14
Honda owns me
typemismatch's Avatar
You'll only have valve problems if you didn't do it right, or if your belt broke.
typemismatch is offline   Reply With Quote
Old 06-24-2011, 08:02 AM   #15
Im pretty sure the belt broke, I was driving and the car made a wierd noise and then shut off, it makes a crazy whinding noise when I try to start it now
Old 07-06-2011, 02:09 AM   #16
can someone send me the info on how to do timing belt plz..
lilpimp_2004_90@hotmail.com
1994preludevtec is offline   Reply With Quote
Old 10-22-2011, 02:00 AM   #17
can u send me thefull pdf file on how o do timing on h22 thanks..
there are _ in between so _2004 and _90
Old 03-07-2012, 07:27 PM   #18
Danny Fallas's Avatar
Icon2 Re: How To Set H22A1 Timing Belt?
Hi there, I don't know if you still have the PDF but i need it because when I align the balancers i don't know how to.
The engine have a little vibration after this.
Thank you
Danny Fallas is offline   Reply With Quote
Old 03-07-2012, 07:43 PM   #19
The two cams have the "up" mark on them put them up and make sure the other notches are directly parallel to each other and that they are aligned with the head/valve cover gasket area it should look like this cam1(-UP-) cam2(-UP-) make pretend the up is the top notch and the other two lines are the notches when the cams are aligned as in up will be straight up. The crank one is easy it has the arrow pointer on the block and on the crank gears. Now the balancer shaft is tricky but easy there is a bolt behind the block where the water pump is located but alittle under it take it off and insert a screwdriver in so that the rear balancer is lock when you spin it. The other one has a line on the gear and a line on the shaft put the line on the shaft with the arrow on the block. That should have your timing set.
hondasdohc is offline   Reply With Quote
Old 03-09-2012, 04:34 PM   #20
TheJGB3's Avatar
Here it is for a H22A4
TheJGB3 is offline   Reply With Quote
Old 03-09-2012, 04:41 PM   #21
Prudz_lude's Avatar
kaizenspeed put out an even better product than the h23 manual tensioner
http://www.kstuned.com/detail.src?SKU=Kai-H22TT&C=&S=
Wish they put it out a few months sooner :p
Prudz_lude is offline   Reply With Quote
Stupid H22 Timing Belt Tensioner!!!!! serjey15 Honda Prelude 29 11-27-2010 04:50 PM
changing the timing belt on an 02' odyssey stevescivic Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 3 07-20-2007 06:55 AM
adjusting my valves ge_itr Honda Prelude 4 07-14-2006 11:25 AM
Does anyone know how to remove the swaybar endlink? Dai_Ca_Vietnam_H22a4 Honda Prelude 4 02-09-2006 03:09 PM
H22a Started on First Crank M1kevtec Hybrid / Engine Swaps 7 09-25-2002 10:43 PM
Tags
99, bel, belt, change, engine, h22a1, honda, jumps, prelude, set, tensioner, timeing, timing, tool, vtec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
