How to: Install your wwrs lip kit 5gen - Honda-Tech
Old 03-03-2009, 12:52 PM   #1
nordic97mist's Avatar
Default How to: Install your wwrs lip kit 5gen
Since the wwrs kit is basically a PITA to install thought i'd make a thread about how to install it from a normal persons point of view.
Front:
I dont have the front so anyone who has a front installed, would you like to add to this piece please?
Sides:
1. You do not need L brackets. They are basically worthless really.
2. Use double sided tape on the door sill part, it holds just fine.
3. Put double sided tape on the top of each end near the wheel wells
4. Have a friend help you to line it up and get the door sill part and wheel well part lined up and put onto the car
5. Put two self tapping screws on the under side in that flap piece. Use a jack or have a friend hold that flap to push the sides out and give it that "flare" the wwrs is known for
(wasnt able to get all of it since the car sits to low, but you can see one. These screws are to push the skirt out to help with flusness and give it that "flare")
Front:
Rear:
(how the sides look from a distance)
Rear:
1. You can either leave the black rear part on or take it off. W/e you feel comfortable with
2. Line the black rear piece with double sided tape
3. Put the wwrs rear piece onto the black piece until it is nice and even through out
4. Put two screws through the lip into the black piece on each wheel well section and three screws on the flap on the underside of the rear lip into the black piece as well
(Wheel well screws)
(Wasn't able to get a good one of the flap, but you can understand that part i assume)
5. Get three scissor jacks and jack them up on each corner and one in the center to push the rear lip against the black piece to help the tape harden and stick (the longer you leave it the better, even leave it like that overnight for several wks and it will stick, i had a lot of problems with sagging but this solved the sagging problem)
(How flush the rear sits when you do this for a while)
(And from a distance)
Hope that helped anyone with issues installing their wwrs kits. This is exactly what i did and its worked fine since. PM me if you have any questions and i will do the best i can to help
Jesse
nordic97mist is offline   Reply With Quote
Old 03-03-2009, 06:14 PM   #2
Default Re: How to: Install your wwrs lip kit 5gen
Tape is sketchy bro.
senser1080 is offline   Reply With Quote
Old 03-03-2009, 06:44 PM   #3
Well. Ive been using just what ive posted since Nov 2008 and havent had any problems with it. For the wwrs...isnt much else you can do on the rear
Old 03-03-2009, 07:15 PM   #4
jcball3r's Avatar
Looks nice
jcball3r is offline   Reply With Quote
Old 03-03-2009, 08:09 PM   #5
5thgen_er's Avatar
dont like the back lip and tape? psh
5thgen_er is offline   Reply With Quote
Old 03-04-2009, 12:02 PM   #6
seanperia's Avatar
Most cars from the factory uses double sided 3M tape with help of some screws.
seanperia is offline   Reply With Quote
Old 03-04-2009, 01:34 PM   #7
Quote:
Way i did it...uses just those materials.
EG Race Car Part out TopEndUSA For Sale 12 04-23-2011 02:15 PM
Dc2R Spoon N1 & Silencer Mint Condition 01-0720 Mid-Atlantic (Sales) 16 11-05-2009 02:28 AM
Help me make these Evo 9 recaro seats fit my gsr!! wunfstgsr Welding / Fabrication 2 03-21-2009 07:20 PM
mugen si crusher (mugen inside) pblockfinest Honda / Acura 84 09-01-2008 07:29 AM
JDM NATION NIGHT SHOTS pblockfinest Honda / Acura 12 08-19-2008 09:54 AM
Tags
92, 98, civic, honda, instaling, install, installing, kit, kits, lip, prelude, rear, tsx, wwrs, wwrses
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
