How to install Piston rings? - Honda-Tech
Old 05-10-2006, 06:34 PM   #1
PWRDbyHseries's Avatar
Default How to install Piston rings?
Well i am refreshing my engine and i dont know how to "clock" the rings and was just looking fo rsome help with that...
PWRDbyHseries is offline   Reply With Quote
Old 05-10-2006, 06:47 PM   #2
BDRphaSe2's Avatar
Default Re: How to install Piston rings? (PWRDbyHseries)
were they but up your supposed to have em at like, 12o clock, then second one at 3 oclock, then 6 then 9 get it?
BDRphaSe2 is offline   Reply With Quote
Old 05-10-2006, 10:00 PM   #3
Master H Technician
JTCdudeman's Avatar
Default Re: How to install Piston rings? (BDRphaSe2)
Quote:
.Heh... not what Honda or any other ring/piston manufacturer suggests, but ok...
Your helms manual should be able to help you in this matter...
The should be approximately 15 degrees off from each other... They shouldnt be directly at above the wrist pins or perpendicular to them... This will help minimize scarring and maximize effectiveness... Please reference the helms manual before trying anything like this as it seems like a disaster waiting to happen...
JTCdudeman is offline   Reply With Quote
Ring Quiz, How much u know about rings? MoreBoost! All Motor / Naturally Aspirated 2 01-31-2008 11:26 AM
Piston Rings eldorko86 Honda Civic / Del Sol (1992 - 2000) 2 09-06-2005 11:19 PM
axle stop ring ronald55555 Tech / Misc 3 01-11-2005 03:04 AM
seating cast piston rings vs moly Jared Forced Induction 2 09-15-2004 04:56 PM
how to gap honda piston rings hontegra Honda Civic / Del Sol (1992 - 2000) 11 10-23-2003 02:44 PM
Tags
1993, accord, clock, clocking, h22, h22a, honda, hondatech, how, instal, install, installing, piston, ring, rings
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
