How far can I push a fully built H22A????
Old 09-27-2010, 07:08 AM
Drifter6508's Avatar
Default How far can I push a fully built H22A????
I have a H22a4 head port an polished EVERYTHING in it is by Super Tech an black nitrate. The cams are from Bisimoto I have the leve 2.4 an Bisimoto cam gears. The block is a JDM H22A its sleeved stock bore size JE Pistos 9:1 compression Egale rods balanced an micro polished crank.... An EVERYTHING is for turbo... My goal is to make around 750-900+hp I was wondering if that was posible on my motor an the way it is built and what kind of turbo to use also how much psi could it handle...???? Im open to any quetions and advice
Old 09-27-2010, 07:18 AM
formerly xmod_supra
codyh's Avatar
Default Re: How far can I push a fully built H22A????
From what i have been told by many on here. Its not about how much PSI/boost the motor can handle, Its about the HP. Cause Im sure the if you had a .50 trim turbo, you would need alot of PSI to get the same result as a turbo with .75 trim and low PSI.
But good luck with your Q! Seems like you have a good setup!
Old 09-27-2010, 08:50 AM
AznBlueBoy's Avatar
There are a couple already over 700whp.
You can push an h22 as far as your wallet takes you....
Old 09-27-2010, 09:19 AM
md23vtec's Avatar
Goodluck on making 750 plus with those eagle rods and bisi cams.
Old 09-27-2010, 12:32 PM
Sales@Bisimoto.com's Avatar
Hmmmm,
what will dictate your potential goals is what you use internals wise as well as turbo setup. Bearing this in mind you have a good starting setup but do not forget you will need a good engine management setup as well!
Please let me know what else I can assist you with
Randy@Bisimoto.com
Old 09-29-2010, 04:46 AM
I live under a rock
spoolinlude's Avatar
There's 800hp H22's out there.... the motors are just as capable as the B-series motors once they're built properly. You need a stout fuel system for that kinda power though, and a large frame turbo.
Old 09-29-2010, 02:41 PM
dagle's Avatar
Listen to this man OP. he's like Jesus in the Prelude world .
Old 09-30-2010, 08:11 AM
TurboBB2's Avatar
^^ what he said.
Oaks has a prelude making pretty nasty power well over 8, almost 9 last time i talked with them. be ready to break some stuff and have some spending money.
IMO i dont see the point for such high numbers unless your competing... you just cant really have fun with it cept for a few passes on the strip.. keep it at like 4-650 or so. You can almost make the same run times anyway since traction issues.
H series is more capable than B.. bro
Drifter6508
11-18-2011 05:07 AM
Drifter6508
09-27-2010 09:44 PM
Drifter6508
Engine Management and Tuning
09-27-2010 02:18 PM
Drifter6508
09-27-2010 08:01 AM
94CDMeg
09-25-2008 07:47 PM
Quick Reply: How far can I push a fully built H22A????
