How do you troubleshoot a bad catalytic converter??
Re: How do you troubleshoot a bad catalytic converter?? (Deckedlude)
Usually a rotten egg smell from the exhaust is a good indication of a bad cat.
Play with this website's Trouble Shooting guide for awhile
http://www.autozone.com/servle...=info
Modified by Behan at 9:38 PM 8/10/2004
Re: How do you troubleshoot a bad catalytic converter?? (Behan)
bang on it. if it rattles that means it's broken. also if you have a laser thermometer you can measure the temp b4 and after the cat. if the temps are drastically different it's clogged.
Re: How do you troubleshoot a bad catalytic converter?? (18gLUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gLUDE »</TD></TR><TR><TD CLASS="quote">bang on it. if it rattles that means it's broken. also if you have a laser thermometer you can measure the temp b4 and after the cat. if the temps are drastically different it's clogged.</TD></TR></TABLE>
Regarding the temperature: Outlet temp will be 100 degress F more than inlet temp.
Re: How do you troubleshoot a bad catalytic converter?? (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">Is there a decisive way to tell if a catalytic converter is working or not??
Thanks
Andy</TD></TR></TABLE>
Most conclusive would be an emissions test.
If the emissions test shows elevation of CO and hydrocabrons, then its the cat. 80-90% of CO and HC's channeled into the cat ( if the car is warm) should be eliminated by the catalytic converter (if it's working).
Thanks
