how to do Compression test?
Re: how to do Compression test? (SupRlude01)
go buy a compression tool at autozone its like 50$. then warm up your motor to operating temp turn it off, pull the fuel pump fuse and pull the cable off the coil then remove your spark plugs and check one by one tunring the motor with the ignition for 5-6 turnovers at a time. the cylinder pressure should hold. write down yoru results and post em on the board. good luck
