Hondata IM gasket installation tips
Old 07-31-2003, 09:43 AM
BolivianFuego's Avatar
Default Hondata IM gasket installation tips
Im about to install this on my lude. Do i have to take out the whole manifold or can i just take it apart and pull out the old manifold and put in the new one without taking it all out?
Old 07-31-2003, 09:50 AM
New User
laughinxxx's Avatar
Default Re: Hondata IM gasket installation tips (BolivianFuego)
take your IM off of the head. Put the Hondata gasket in after scraping off the old gasket. Put IM back on.
Old 07-31-2003, 11:34 AM
ludegirl1004's Avatar
Here are some pics from my car...have fun scraping off the old gasket.
Before:
After:
Old 07-31-2003, 11:44 AM
94vtecmn's Avatar
Default Re: Hondata IM gasket installation tips (ludegirl1004)
What exactly does this do for the car?
Old 07-31-2003, 12:04 PM
h22a193's Avatar
lowers intake manifold temps, by blocking some heat from the head. This equals more power!
Old 08-01-2003, 05:18 AM
Keith's Avatar
How hard was it removing the lower IM? Did you use gasket remover to take off the old gasket? I'm tackling this in a couple of weeks. I'm thinking it should take about 3-4 hours.
Keith
Old 08-01-2003, 05:33 AM
SKDRCR's Avatar
Default Re: (Keith)
And what else dou you have to remove to get access to all
the manifold bolts
Old 08-01-2003, 09:48 AM
Default Re: (SKDRCR)
Yes wat else? Im scared im gonna not be able to do this.
Old 08-01-2003, 05:54 PM
mt23vtecbb2's Avatar
Default Re: (BolivianFuego)
screw that i put mine on wile the motor was out... taking the im off would suck.
Old 08-01-2003, 06:51 PM
93accordEX's Avatar
Default Re: (mt23vtecbb2)
yea not to scare you off but I did it with the motor out too and i think it would be damn hard with it in.
Old 08-02-2003, 07:13 AM
fastludeh22's Avatar
Default Re: (93accordEX)
moter out here also... i drilled a hole in it, so it wouldn't block off the egr there, i blocked it off right at the egr itself, incase i need to have it fuctional i would not have to pull the itm.
Old 08-02-2003, 02:12 PM
TimeRacer's Avatar
Default Re: (fastludeh22)
Did it with the motor in, you could take the manifold off in less than an hour and a half. It's the gasket that's a pain in the ****.
Old 08-02-2003, 04:31 PM
H22NOSACC's Avatar
It took me 5-6 hours with the motor in and a lift, pain in the butt, barley worth it, my suggestion spend the 100 dollars else where first
Old 08-02-2003, 10:33 PM
sharkcohen's Avatar
Default Re: (H22NOSACC)
I installed my hondata gasket with the engine in the car. I didn't think it was that difficult. One can of spray gasket remover, 3 hours of scraping.
Old 08-07-2003, 12:31 AM
Import Alliance
Don Napier's Avatar
Default Re: (sharkcohen)
here is a dyno graph of the NextGear gaskets.
http://home.comcast.net/~nextgear/
Old 08-07-2003, 01:08 AM
SsTiNgEr77's Avatar
Default Re: (egCivicDon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egCivicDon &raquo;</TD></TR><TR><TD CLASS="quote">here is a dyno graph of the NextGear gaskets.
http://home.comcast.net/~nextgear/</TD></TR></TABLE>
negative
Old 08-07-2003, 08:29 PM
Import Alliance
Don Napier's Avatar
Default Re: (SsTiNgEr77)
Negative
Call the place I dynoed the gaskets at
Old 08-07-2003, 09:37 PM
SKDRCR's Avatar
so the gasket blocks off the egr??
how can blocking the egr benefit you?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">moter out here also... i drilled a hole in it, so it wouldn't block off the egr there, i blocked it off right at the egr itself, incase i need to have it fuctional i would not have to pull the itm.</TD></TR></TABLE>
Old 08-07-2003, 11:24 PM
bew
Guest
Posts: n/a
The NextGear IM Gaskets did in fact make 10whp at Performance Garage in Nashville. I know the owner of the car it was dyno'd on.
Old 08-08-2003, 12:48 AM
SuperSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">so the gasket blocks off the egr??
how can blocking the egr benefit you?</TD></TR></TABLE>
The EGR (exhaust gas recurulation) pulls hot exhaust into the intake making the intake charge hotter defeating the purpose of the gasket. It does that to reduce emissions and help prevent detonation to some extent.
Old 08-08-2003, 06:20 AM
SKDRCR's Avatar
Default Re: (SuperSH)
so are you saying that w/o the egr blocked off
there is no benefit to the gasket
Old 04-05-2006, 01:33 PM
SNsLude's Avatar
sorry to bring it back from the dead haha... but yah, through searching i've read mixed replies about needing to block the egr off and what not. So is it true that if you don't block off the egr valve that it'll deem the hondata IM gasket pointless?
Old 04-10-2006, 11:31 AM
SNsLude's Avatar
Default Re: (SNsLude)
anyone?
Old 04-11-2006, 12:30 AM
AdReNaLiN's Avatar
It wont deem it pointless - but it will reduce its benefits...
Old 04-11-2006, 04:07 AM
RTFM
v4lu3s's Avatar
heat transfers a lot better from metal to metal than from gas to metal, yes the gasket does do good even with a working egr system, though losing the egr makes it evehn cooler.
Quick Reply: Hondata IM gasket installation tips
