Honda vs. Synthetic Auto Trans fluid - Honda-Tech
Old 12-17-2013, 03:58 PM   #1
Default Honda vs. Synthetic Auto Trans fluid
I want to clarify a couple of things: (I own a 97 Prelude 4spd automatic with 83.000 miles)
1)What is best for my transmission and it's longevity; standard or synthetic trans fluid?
2)Is it better to drain and refill or hook up to a machine when changing fluid?
I have yet to get any decisive answers for these questions from mechanics or the Honda Dealer. I'm okay with spending the extra cash if I know it will benefit the transmission.. Any thoughts to the above concerns?
I have heard varying opinions on what type of fluid to use and/or if it is good or bad to have the transmission flushed by machine (some say it can damage the seals?) Right now, I believe there is generic fluid within...
khafre3 is offline   Reply With Quote
Old 12-17-2013, 04:28 PM   #2
nemesis25's Avatar
Honestly, Honda makes the best fluid for their transmission, Atf
z1 or Atf Dw1 is Fine. However, Honda didn't do a good job at designing this particular transmission to last. In regards to fluid change, I like to flush and fill without a machine. There's a video on how to do this on YouTube.
nemesis25 is offline   Reply With Quote
Old 12-17-2013, 09:07 PM   #3
Sparksman's Avatar
Default Re: Honda vs. Synthetic Auto Trans fluid
You're trans will more then likely go out for non-fluid related reasons. Just use Honda brand ATF and call it a day.
You dont need a machine, those are only there to make mechanics lives easier.
Sparksman is offline   Reply With Quote
Old 12-18-2013, 08:07 AM   #4
integra_101's Avatar
i only use honda tranny fluid.
if it was made specificity for hondas, use it.
integra_101 is offline   Reply With Quote
Old 12-19-2013, 05:44 PM   #5
The flush machines should never be used on a Honda, Honda will even void a warranty if one has been used, it's a huge no no.
It's not just Prelude transmissions guys, a lot of late 90's and early 00's Honda's had the same issues as well as the warranties being extended, it was a bad time for Honda's AT's. I work at one, actually see way more Odyssey, Civic and Accord AT's go out than Preludes but then again no one brings Prelude's to the dealer, those along with S2000's are usually pretty poorly maintained.
The engineers know way more than you or any aftermarket company as far as the fluid goes, if your transmission is going to fail then it will fail, if it does best to buy a Honda reman'd unit that has the problems addressed and has a 3yr/36k warranty. Way better than most transmission shops 1 year warranty. The reman'd units are pretty reliable.
minilogoguy18 is offline   Reply With Quote
OK to replace auto trans fluid with synthetic? ginahoy Transmission & Drivetrain 10 11-09-2014 04:27 PM
Changing trans fluid to DW-1, drain and fill or flush? OldMrAccord Honda Accord (1990 - 2002) 3 06-26-2011 05:25 AM
transmission fluid?? honda-guy72 Honda CRX / EF Civic (1988 - 1991) 32 09-21-2008 10:54 PM
transmission fluid mistahmac Honda Civic / Del Sol (1992 - 2000) 7 07-18-2007 02:40 PM
Auto Trans Fluid Change? typer_801 Tech / Misc 10 02-05-2002 10:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
