Shaft seal for distributor H23A1?
1994 Honda prelude Si. I have an oil leak coming from the bottom of my distributor, it leaks all over the coolant temp sensor and sender. I believe this is caused by an O-Ring called the outer shaft seal or something like that. Anyone know if I am correct and if so where I could find this part? Having trouble looking it up. Oil does not leak into the distributor itself, just where the distributor meets the cam. It's a slow leak, not bad at all, but it's annoying me a bit and I want to fix it.
Re: Shaft seal for distributor H23A1?
you will need to use a marker to make a mark on the dizzy where it meets the head so that when you take off the dizzy you can put it back in the same exact spot so you don't change the ignition timing
Vtec_India
02-15-2016 10:15 PM
