HELP: rear main seal leaking again......... - Honda-Tech
Old 07-05-2009, 07:38 PM   #1
Default HELP: rear main seal leaking again.........
i have an 1997 h22a4 and had a bad clutch slip due to a bad rear main seal any help would be appreciated
first i removed tranny had flywheel resurfaced and replaced rea main seal replaced clutch and put tranny back on an ran grat then 2 days later what do you know its leaking again so we take it back off and the seal is still leaking am i missing somthing? we instaled te seal correctly and the seal retainer isnt leaking but maybe there is a common or known problem any help would be very much apreciated what are the feeler gauge clearances for the seal to crankshaft. thanks
h22funbags is offline   Reply With Quote
Old 07-05-2009, 08:46 PM   #2
vinuneuro's Avatar
Default Re: HELP: rear main seal leaking again.........
vinuneuro is offline   Reply With Quote
Old 07-05-2009, 09:17 PM   #3
KWayRacing's Avatar
Are you sure it is the rear main again or maybe a tranny input shaft seal?
KWayRacing is offline   Reply With Quote
Old 07-05-2009, 10:13 PM   #4
after I took it apart again I used the biggest feeler gauge I had (.027) between the seal and the crank, It went in and all around with no resistance, maybe I just got the wrong seal
Old 07-07-2009, 05:19 PM   #5
KWayRacing's Avatar
ould have rolled the lip who knows OEM seal and you should be good. Good to hear.
Old 07-08-2009, 04:06 AM   #6
bluedlude's Avatar
after a while the rear main seals wear a groove into the crank, if you by chance lined up the lip on the new seal with that groove it will probably leak on ya
bluedlude is offline   Reply With Quote
Old 07-08-2009, 11:03 AM   #7
put a new seal in on mon. so far so good, thanks for the input, i think it was a defect
Old 03-26-2010, 10:13 PM   #8
8 months and its leaking again
Old 03-27-2010, 10:20 PM   #9
young_tuner's Avatar
better it was 8 months and not 2 days..
young_tuner is offline   Reply With Quote
Oil leak on oil lan where transmission meets...main oil seal? 05foresterxt Honda Civic / Del Sol (1992 - 2000) 12 12-30-2010 04:59 PM
Paid a shop $350 for Rear Main seal.. 2 weeks later.. dth0ng69 Honda Civic / Del Sol (1992 - 2000) 30 10-08-2009 04:29 PM
Oil Leak d16y7, Replaced rear main seal. dth0ng69 Honda Civic / Del Sol (1992 - 2000) 4 08-29-2009 11:08 AM
transmission bell housing leak sweesiong78 Honda Civic / Del Sol (1992 - 2000) 4 07-02-2008 01:41 PM
lil oil question FERIOkid Honda Civic / Del Sol (1992 - 2000) 13 11-02-2004 10:20 PM
Tags
06, 2003, 90, accord, civic, h22a4, honda, leak, leaking, main, odyssey, prelude, rear, retainer, seal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
