HELP!!!!!!! h22a1 in 94 SI i have probs
hello everyone.. I know alot of you will say "SEARCH NOOB" and i already have. I have found that the Si preludes were prewired for Vtec. And i looked under my hood and looked for these 2 wires everyone is always talking about. I found a green/yellow stripe (vtec solenoid wire) and a just straight blue wire. They are in my harness in the engine bay but they have lil blanks plugged into them ( capped off)...
Now being i found these wires...Now my question is. Where in the hell does this blue wire plug into? I beliveve it is called vtec oil something. I know i sound vauge but i am very confused.
I see that the vtec solenoid wire is there and i know how to hook that up. Thats no problem. I just need to know where this blue wire plugs into. PLEASE SHOW PICS.
ALSO. i do have a p13 coming on the 1st...so i wanna have all these wires set up and ready so that i can just plug my p13 in and have vtec.
I read somehwhere that the car is prewired for vtec, and i realize that. and i do have my 2 wires located like everyone talks about. But PLease explain what i do inside the car..i pulled my carpet back and stuff and i see the p14 ecu..but i dont see the blue wire or the green/yellow stripe wire. Where are they at in the floorboard?
edit: i just talked to a honda techn and he said that the wires are in the harness and plug into the p14 ecu but are not used.
So this sounds like to me... i need to plug in my vtec solenoid. FIND this plug where the blue wire goes to, get my p13, plug it in. and go! is this right? and please ONLY ANSWER IF U KNOW FOR SURE.
find out whats not plugged in, i have aan si with a jdm h22 in it and i didnt see it prewired for vtec was weird, so i wired it myself, found a diagram off here and wired it up and just grounded it to fender boltbut there should be 1-2 wires from solenoid and 2 from switch
Re: (All-Motor-Junkie)
^^ that doesnt help bro...
i am using a usdm h22a1
what i am saying is...i need to know where this plug plugs in...its the blue wire.
i have my green/yellow vtec solenoid plugged in now..so that shouldnt be a problem
can someone who actually did their swap themselves into a 94-95 si please show where that blue wire goes... please help me..their is like thousands of luders on here and i know some of yiou have actually done the swap yourself.
I had a 96 prelude original vtec 88k miles.. i did this swap myself and everything is plugged in and workin..i just know that when i get my P13 in a week, i will need to have these wires hookedup so my vtec will work CORRECTLY..
HELP PLEASE
Modified by sleepyH22 at 5:38 PM 9/26/2006
HELP PLEASE
Re: (sleepyH22)
I swapped an a4 into my 95 Si a few years back.
That wire should go straight to the harness by the ecu. Pin D6, oil pressure switch. Check for continuity for that pinout at the harness side. Run a jumper from the blue wire to a power source (battery), then check the pin at D6 for continuity. If it lights up, that's your oil pressure wire.
Re: (Finest)
i understand that. now where does it plug in on the motor?!
i see where vtec green/yellow is there and fine. but this BLUE WIRE goes to nothing under my hood..it just sits there and i know it is vtec related. now where does it plug in on the motor?
Re: (sleepyH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyH22 »</TD></TR><TR><TD CLASS="quote">i understand that. now where does it plug in on the motor?!
i see where vtec green/yellow is there and fine. but this BLUE WIRE goes to nothing under my hood..it just sits there and i know it is vtec related. now where does it plug in on the motor?</TD></TR></TABLE>
Under the VTEC solenoid is a gray or white plug. That's your VTEC oil pressure switch. Did you get an H22 wiring harness to go along with the motor? If not, you'll need a spare connector that'll fit in that sensor and wire the blue wire to it.
Re: (sleepyH22)
no i do not see it...all i see is the vtec solenoid and its plug and the tiny brackey that holds the plug.
CAN YOU PLEASE take a pic of it so i can see where i need to plug it in at.THANKS!!
Re: (sleepyH22)
BTW, i do have a full obd II h22 harness....i understand that i will need the plug off it and attach it to the blue wire...but where would this plug plug into? i need a pic!!
Re: (v4lu3s)
so what wire to i use then? i got the vtec solenoid wire done..
i cut my plug and some wire off the h22 harness so now i have the vtec OP plug...it has a light blue wire and a black/ blue stripe i think...what do i do now?
Do not purchase anything from me. -HT Staff
Re: (sleepyH22)
i believe that single blue wire and plug is for honda optional fog lights.. thats how it was on the civics.. the fog lights plugs into those single blue wire.. hope that helps
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">the single wire plug with the blue wire is your tech test lead NOT anything to do with vtec.</TD></TR></TABLE>
Like I said earlier, check continuity of the wire to pin D6 to see if it is infact the correct wire. Otherwise, run a new wire from the VTEC oil pressire switch to that pin position.
The other wire on the VTEC oil pressure switch goes to ground. Ground it on the thermostat nearby.
Re: (Finest)
ok, i can repin. thats no prob. Now my question is...
What about the wires (meaning vtec solenoid and vtec OP) the 2 that i pin in the correct ones stated above. What do i do with the 2 wires that are currently in those specific pins. do i just leave them out and go to nothing or what? i am looking at it as...yeah it no prob doing these two wires and vtec solenoid and vtec OP work fine but after that i am going to have 2 random wires going to nothing at the ecu???
Re: (sleepyH22)
OK...i got all my wiring done...the light blue wire for the vtec OP was right by the fuse box under the hood... i ran it to the vtec op and did the ground...
I also extended my vtec solenoid wire and it is plugges in also...so now all i am waiting for is my p13... 5 more days til i buy it and it'll be on it's way.
Re: (sleepyH22)
congrats sleepy im on the same boat right now lol 92 si to h22a but im using my h23 harness so i just gotta get the plugs for the vtec solenoid and op and run it str8 to the ecu but im having issues since i have an internal coil on my distributor and the h23's had an external so now i gotta get an h23 distributor and external coil =/
FUP23
02-24-2002 04:35 AM
