Help? Euro r H22a - Honda-Tech
Help? Euro r H22a
Old 03-09-2017, 03:31 AM   #1
Default Help? Euro r H22a
I am new to the Honda game. This will be my first build. It's an H22a euro R in my 93 Honda prelude. I was just wondering which valvetrain upgrade would be best ? (Valves, cams, cam gears, springs, retainers, etc.) if anyone can give me any ideas much appreciated
JE RR is offline   Reply With Quote
Old 03-09-2017, 11:08 PM   #2
Default Re: Help? Euro r H22a
I would say that match the valvetrain to cams (usually manufacturers have "sets").
Like brian crower cams and their valvetrain.
Better cams also benefit from higher compression (better pistons) but that means bigger (and more expensive) build also.
Hows your header and exhaust situation? Make sure that is "up to date" as well before you start to change internals.
You need to do some research there by yourself, cannot really say what characteristics you want for your engine....
Usually people go with Skunk2 Pro or Brian Crower cams. (I've become little bit paranoid about rocker wear with aftermarket cams so I went from Skunk2 to OEM JDM)
Also you need engine management (like Hondata) for proper tuning if youre doing major changes
TimiK is offline   Reply With Quote
Old 03-10-2017, 02:21 AM   #3
Makes a lot of sense (wasn't thinking straight ) so for the basic bolt ons I.H.E Which would you recommend? Or brands ?? And you said you went from skunk2 to oem Jdm ? Which cams are best oem jdm? Isn't the euro R the best cams ? Which cams recommend
Old 03-10-2017, 03:35 AM   #4
H22 Type S/R engines have the most power.
I would stick with your current cams and upgrade exhaust part first. You have to drop insane amount of money into these engines if you want to make serious hp numbers.. cost-gain ratio is not that good.
3" exhaust makes most power - headerwise maybe some PLM tri-Y product?
For intakewise stock intake is pretty ok IMO, just change better flowing filter there. Then tune.
If you have Type R engine already there (and its healthy engine), its already pretty decent so I would start to upgrade other parts of the car more than the engine (exept exhaust). Suspension, maybe some weight reduction etc
Just my opinion.
Old 03-16-2017, 03:10 AM   #5
Okay sounds good I greatly appreciate the thoughts/opinions now ... let's say stock euro r H22a on boost how much psi can it handle with a To4e turbocharger kit. eBay kits for now
Old 03-16-2017, 06:57 PM   #6
Quote:
Not good engines for turboing unless you build the block
Old 03-18-2017, 04:29 AM   #7
One last question if someone can please answer / help me out. I have the H22a euro r motor in my 93 prelude but im not running the euro r manifold. I currently have the oem 93 h22a1 manifold. Euro r manifold didn't seem to fit if anyone can help me out with this fitment. I much rather have the euro r manifold I hear there a lot better
how to fit euro r manifold with euro r H22a in 93 prelude
Old 03-18-2017, 08:05 PM   #8
Rosko racing.com
H22A Euro R complete head and IM 92SR4WS For Sale 1 12-11-2016 09:07 PM
h22 euro r questions DAZZLESA Honda Prelude 3 09-26-2016 10:26 AM
ecu pinout h22 euro r keith hickey Honda Accord (1990 - 2002) 1 05-16-2015 03:11 PM
Euro-r vs Type S cams??? 92civlude Honda Prelude 1 01-22-2009 09:08 PM
ported Euro R IM expected numbers WeekH22#2 All Motor / Naturally Aspirated 1 10-14-2006 07:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
