Help with CEL code!!!
Old 03-01-2005, 12:20 PM
bauer778's Avatar
Default Help with CEL code!!!
The other my CEL and ATTS lights came on. Car still ran the same i could not tell any difference in the performance. I went to Advanced Auto to get the codes checked. IT came out as P0401 EGR Flow Insufficient. does this mean that i have to replace the EGR valve? What could cause this code to come up.
Thanks
Dan
Old 03-01-2005, 01:22 PM
britishlude's Avatar
Default Re: Help with CEL code!!! (bauer778)
Insufficient flow could be your EGR sticking through being made up with deposits or ports restricted with gunge, try cleaning EGR in carb cleaner first.
Old 03-01-2005, 02:35 PM
98TypeSH's Avatar
Default Re: Help with CEL code!!! (britishlude)
If that doesnt do it then it is possible that the EGR port on the intake manifold is full of gunk. To clean that the intake manifold needs to come off the car.
Old 03-01-2005, 04:52 PM
mjcannon's Avatar
Yeah, I'm having the same problem, replaced the egr, still the cel comes on, the mechanic who did the install cleaned the intake ports as best he could without removing the im, and honda gave him another new egr just in case, still with the cel, so I did the "suck" test on the egr vacuum hose to manually open the valve, the engine should labor or stall with the egr open at idle, mine slowed about 200 rpm, but didn't stall. Also manually jumpered the egr solenoid to eliminate that as a possibilty, works fine. Only things left are blocked egr ports or bad ecu, don't think the ecu is bad though, they very rarely fail, apparently, so I'm gonna try cleaning or replacing the im, someone was kind enough to post instructions if you want them, can't vouch for their accuracy just yet though, may also replace the im with something a little bigger (skunk2).
Old 03-02-2005, 02:51 PM
bauer778's Avatar
Default Re: Help with CEL code!!! (mjcannon)
thanks guys ill be cleaning the EGR valve in a few days, i hope thats the problem. I dont feel like taking the IM off
Old 03-02-2005, 02:54 PM
98TypeSH's Avatar
its really not that hard to get the IM off. Just make sure you dont drop any of the bolts. I dropped 2 and spent like 4 hrs looking for them. lol
Old 03-03-2005, 06:04 PM
mjcannon's Avatar
Yeah, I don't feel like taking mine off either, check the egr first, that's the easy part. If you're lucky, that'll take care of it.
Old 03-07-2005, 07:55 PM
bauer778's Avatar
Well i took off and cleaned my EGR today, it was a mess, i took like 30 min and made it nice and clean. I put everything back together and took it out for a drive everythign was fine. I was driving tonight and the CEL came back on. IM guessing i have to take the IM off. Can anyone tell me how to go about doing this. Is there a write up or somethign
thanks
dan
Old 03-08-2005, 06:11 AM
There's a link here for an exploded diagram of a 5th gen intake manifold, can't help you further as I've never taken mine off, I would suggest getting a Helms if no one can supply a write up.
http://www.hondaautomotivepart...IFOLD
dragon_lowrider
12-11-2010 11:11 AM
Greg50Lt
Honda Civic (2006 - 2015)
04-07-2008 09:31 AM
Arsenal
03-19-2008 02:39 PM
typeSH714
04-11-2006 12:54 PM
B18C-RnVA
04-01-2002 09:31 PM
Quick Reply: Help with CEL code!!!
