headlight install
Old 08-22-2003, 08:41 AM
Luder85's Avatar
Default headlight install
Is there a bracket on USDM headlights directly underneath the corners, because there is one on JDM headlights. Do JDM headlights' brackets match USDM specs exactly the same? I know that there is no screw for the corner anymore for the JDM headlight because it is one piece...anything else?
Old 08-22-2003, 08:50 AM
madcatz's Avatar
Default Re: headlight install (Luder85)
you have to remove the entire front bumper, and front bumper support. There is no other way around it...its really straight forward when you get the bump support and bumper off. Just pretty much get the holes linned up and then get the bumper and all put back on.
Catz
Old 08-24-2003, 07:56 AM
PetroGuyX's Avatar
i just got done with that project, it's really not that tough, it took me 45 minutes to an hour to take my bumper off without knowing which nuts and bolts to take out, good luck with that, check out my jdms
Old 08-24-2003, 09:04 AM
JBG's Ferio's Avatar
Default Re: (PetroGuyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PetroGuyX &raquo;</TD></TR><TR><TD CLASS="quote">i just got done with that project, it's really not that tough, it took me 45 minutes to an hour to take my bumper off without knowing which nuts and bolts to take out, good luck with that, check out my jdms </TD></TR></TABLE>
Or you could just slam into a guardrail like I did to get your bumper off
Old 08-24-2003, 10:19 AM
Do it right the first second time!
Chief Brody's Avatar
Default Re: (J B G)
Step by step instructions with pictures....let me know if it helps http://www27.brinkster.com/sons/jdmlights.html
Scout
11-18-2008 05:16 PM
Eagle16nam
03-09-2006 07:45 AM
TxTuner
08-15-2004 07:16 PM
Francois
04-27-2003 07:09 AM
SpeedMonkeyRacing
09-06-2001 01:25 PM
Quick Reply: headlight install
