Have two gas lines & I need help!!!
So one of the gas lines has gas coming out the other is the return I believe and need HELP to where they plug
Does the one that has gas coming out go to intake manifold or fuel pressure regulator?
and same with return fuel
I have an H23 vtec BTW
Re: Have two gas lines & I need help!!!
Ok, so the gas comes from the tank to the fuel filter, then to the fuel rail, then to the fuel pressure regulator, then to the return line back to the tank.. Im not sure which line ur talking about without a pic.
I think I figured what you were saying but just to make sure I'll getting a pic tomorrow
If this helps you right now I have a 2000 accord
