H23Vtec need your help please!
I've search and couldnt come up with a solution. This is for a 97 Prelude
I have a 93 H23 Bottom, with 97 Vtec head. I'm using the 97 Oil pump.
I go to start up the car, and it just spins. it doesnt even chuckle. so I tested the distributor and its good, I test for sparks and its good.
I check the Fuel line and its pressurize because when I losen the feed line bolt fuel sprays out. I have 3 new gallon of 91 octane in the car, and 3 old gallon of 85 octane from like 1 year ago.
I check all the fuses and they're fine
I try to start the car I let the fuel pump prime for 2 or 3 mins before I crank it but it just spins and I cant smell any gas. I mean if I keep on starting the car and flood the engine wouldnt there be gasoline smell. But I cant smell any gasoline. and when I go to pull the spark plugs its dry its not soaking wet with fuel on the tip of it. THe weird thing is that my fuel line is pressurize.
Could this be the fuel pump or the Fuel injectors?
Re: H23Vtec need your help please! (RJonathan)
Where did you take off the fuel feed from? Did you check it before or after the fuel filter? I am thinking that possibly your fuel filter may be clogged.
Re: H23Vtec need your help please! (CivicSiDriver02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiDriver02 »</TD></TR><TR><TD CLASS="quote">Where did you take off the fuel feed from? Did you check it before or after the fuel filter? I am thinking that possibly your fuel filter may be clogged.</TD></TR></TABLE>
True, that can happen, I had half a tank in mine while I rebuilt my engine and happend same thing as you, my fuel filter was clogged, changed it an voila.
chihuahuamanx
05-04-2006 07:44 PM
civic89si666
01-31-2006 05:22 PM
