H23A BlueTop Dizzy swap help
Old 07-05-2010, 09:09 PM
churn dasher's Avatar
Default H23A BlueTop Dizzy swap help
I started this thread on Prelude Power too i wanna get it done tomorrow if i can. When i got my 98 Sh the 00 H23A Blue had only been in it a few weeks. The guy i got it from does'nt know anything about honda's his uncle did the swap. Its running off the p5p sh ecu just fine for now with the whole h22a4 intake mani on it! BUT he hooked the h22a4 dizzy back up to it with the hideous MSD cap and coil. Well i want to use the internal coil dizzy i have the H23A Harness that came with the swap and i can take the plug off it and i do plan on leaving about 4" of wires in it to splice with. Since thers a msd coil my plug that i COULD stick a 30amp fuse in to jump has been cut so i think i can splice them two wires together? ....I just want to know where the RED wire goes from the jdm dizzy when i splice it to the h22a4 harness. If you can help me it would be great.
The plug sticking out facing the header is the jdm dizzy and the one below is the jdm harness where will that red wire go?
Next pic: where will the green wire go that went to the coil "rem" i dont have a plug for the stock coil.
Old 07-06-2010, 12:43 AM
Default Re: H23A BlueTop Dizzy swap help
Well I guess the red wire might be the crank angle
Project_EK
12-06-2009 09:45 PM
tichal2008
11-10-2009 09:20 PM
Stoich EG2
14
01-12-2005 07:17 PM
cb9sir
10-20-2004 07:34 AM
96prelude96
09-14-2002 08:45 PM
Quick Reply: H23A BlueTop Dizzy swap help
