H23 vtec swap in 2000 accord from F23
Old 01-16-2012, 09:39 AM
hondaaccordf23's Avatar
Default H23 vtec swap in 2000 accord from F23
what is the right way in swapping an H23 vtec in accord?
I just read a thread back in 2003 saying people have had broken cranks, spun bearings, and popped timing belts
Old 01-16-2012, 10:24 AM
Phildo916's Avatar
Default Re: H23 vtec swap in 2000 accord from F23
Swapping it doesnt break the crank, bearings, or timing belts. Driving and Revving the engine like a B series or H22 is what kills them.
Old 01-16-2012, 10:38 AM
ic thanks so do you think an H23 would be better than h22
Old 01-17-2012, 07:37 PM
1funryd's Avatar
That is a very broad question. Both motors have their strengths, so its up to you to decide what you are going to use it for.
Old 01-18-2012, 08:12 PM
mainly normal driving basically I usually end up going up hills and occasionally racing people at the lights haha off the line though
Old 01-18-2012, 08:50 PM
elemntsk8r16's Avatar
With the hills you might like the added benefit of the lower end torque with the h23 vtec. Both engines put out about the same torque but your going to hit the powerband much.lower with the h23a. All just depends on what you want. I bought the h23a for the increased displacement and torque from it. Hp wise is exactly the same as a h22a4
Old 01-18-2012, 09:42 PM
if I have a 2000 should I get a 2000 engine b/c on hmotors the h23 vtec says 2000 and h22 92-95 or 97-98
Ethan2536
01-05-2010 07:24 PM
mongtite
10-19-2008 12:19 PM
hotimportcrx
03-19-2006 07:35 PM
shavedH22AKCL
09-15-2005 09:09 AM
Quick Reply: H23 vtec swap in 2000 accord from F23
