h23 prelude NEEDS HELP
Old 04-12-2010, 07:22 PM
jdmeg9's Avatar
Default h23 prelude NEEDS HELP
Alright my DD mrs. 245K on the odometer needs help. last week it died while warming up to chauffer me to work. I started it again noticed that it was at its halfway mark on the temp let out on the clutch and psst she just died. I parked it and drove my civic to work. I worked on it this weekend cleaned the egr, cleaned the nasty gummy throttle body (which I thought either one could of been it)after driving it and noticed if I pressed in the clutch the rpms drop absurdly fast and doesn't even attempt to idle. If I start it up after dieing it will idle and occassionally die. It finally kicked a code after letting it idle numerous times after restarting. I believe I am using the right port as you may have guessed I am a novice to Preludes and Accords I am extremely handy with civics, integras, and the like though. The port I found was in the center under the radio same 2-pin used in the civics that makes the abs light go off and blinks the cel. It kicked code 4 it is obd1 and I found that to be the crank angle sensor. Does this sound like the likely culprit?
Old 04-13-2010, 09:33 AM
jkoni426's Avatar
Default Re: h23 prelude NEEDS HELP
i would test/replace the sensor, reset the ecu, and then see where that leaves u...
Old 04-13-2010, 01:46 PM
jdmeg9's Avatar
I am under the impression that it is located in the distributor.........
Old 04-14-2010, 02:51 AM
jdmeg9's Avatar
bump
Old 04-19-2010, 01:37 PM
jdmeg9's Avatar
really? simple crank angle sensor is in the dizzy so it is kinda expensive. if you really looked it is in 2 forums since the prelude forums is slow and nobody ever responds.
Old 04-20-2010, 02:35 AM
jdmeg9's Avatar
Moderator moved one of them then because I put one in the civic forums and one in the prelude forums. Wow I bet you feel so much better calling me out, go run to the bathroom and polish your tool.
Old 04-20-2010, 01:42 PM
jdmeg9's Avatar
how about you go and kick tires in the BS thread somewhere I am just looking for help
Rekkerslude
Engine Management and Tuning
09-21-2017 10:33 AM
ZAchAtTacK420
12-01-2011 11:51 AM
jdmeg9
04-20-2010 02:37 AM
91backinblack
08-13-2006 08:36 AM
jeffsciv23
03-07-2005 09:01 AM
Quick Reply: h23 prelude NEEDS HELP
