4th generation camber kit
Old 05-11-2011, 09:30 AM
raynor's Avatar
Default 4th generation camber kit
i just bought 2" lowering springs and a camber kit for my 94 prelude. everything came in but a buddy told me the rear is for an integra. will it still work?
Old 05-11-2011, 09:58 AM
Hawkze_2.3's Avatar
Default Re: 4th generation camber kit
No one can tell you that over the internet without knowing details and seeing your parts.
You probably won't even need a camber kit for just 2", I don't.
Old 05-11-2011, 11:47 AM
psychoboy's Avatar
probably not, but without seeing the parts you have, we can't know for sure.
the integra rear kit is usually a replacement for the upper arm:
the prelude rear kit is usually a replacement for the upper arm mounts:
sometimes you'll find an eccentric ball joint for the upper arm:
but i don't know if those will work in the prelude's rear (and i'm not sure i would use them if they did)
so, what did you get?
Old 06-21-2011, 03:04 PM
catchdz's Avatar
its not that bad a little expensive but to get it right it worth it check the internet for myers tire supply get the cataloge and check it comes in to sizes the lower you go the bigger u'll need after installing go to alignment mechanic tell him to check what u need to bring the wheels bck out and go from there, ask for a check and a print out only DONT let them do the alignment till after installing the camber kits
Old 06-22-2011, 05:44 AM
NirVTEC's Avatar
Need, use, want.....
How much (-) camber do you have from a 2" drop. My experience tells me 2*......which I think is a bit much on a street car for tire preservation.
Old 06-22-2011, 09:00 AM
Hawkze_2.3's Avatar
Eyeballing it says <1 degree of - camber, but I haven't properly measured it.
Also looks like it may be closer to 1.5"? I just put new suspension on it recently, and haven't really seen a stock height Lude to compare it to in many years
Old 06-22-2011, 07:57 PM
catchdz's Avatar
I told u to do it right u need to see an alignment mechanic
Old 03-05-2012, 04:56 PM
killa-lude's Avatar
Why don`t you recommend it?
mod5
02-26-2005 02:55 PM
Casual Gcode1
07-14-2003 07:06 PM
PnX-R
04-28-2002 03:37 PM
Quick Reply: 4th generation camber kit
