h22a1 h22a4 crankshaft difference.
Old 04-26-2012, 06:35 PM
dansaleen_04's Avatar
Default h22a1 h22a4 crankshaft difference.
Ok guys I have a major problem. i spun a bearing and they cant fix the crank. I called every single shop, store and crankshaft company through the US and no one has it. I have searched about this topic and although they talk about h22a1 and a4 differences, they dont specifically go into detail about the crank. I need to know if the crankshaft of these 2 engines are different and in which ways. my last option is to buy a new one from the dealer for $992. obviously I am trying to avoid that. Please help me out here guys. Thanks!
Old 04-26-2012, 08:25 PM
asianpoet's Avatar
Default Re: h22a1 h22a4 crankshaft difference.
the difference between them is the journals.. 55 for 98 and up..
50mm for 97 and bellow. if my memory serves me right.
H22A1(93-96)/H22A4(97-98) - MAIN 50mm, ROD 48mm
H22A4(98.5+) - MAIN 55mm, ROD 48mm
B20A1 - MAIN 55mm, ROD 48mm
B16A/17/18/20b/z/etc - MAIN 55mm, ROD 45mm
Old 04-27-2012, 06:06 AM
Rosko's Avatar
Which bearing did you spin? Is the block still good? What year is your Lude?
Old 04-27-2012, 07:01 AM
jnv255's Avatar
My a4 has a 50mm and it's a 97.. As you said they changed it the next year
Old 04-27-2012, 07:41 AM
I spun piston 3 bearing. The block is fine . I have a 2000 lude.
Old 04-27-2012, 09:50 AM
Honda owns me
typemismatch's Avatar
I have an A4 block and crank and most of the stuff to put it back together again
Old 04-27-2012, 04:27 PM
bro how much do you want for it. hit me up either on here or pm. i really need just the crank everything else i have already bro.
orod917
Engine Machining & Assembly
05-13-2019 10:38 AM
mtseidl
Welding / Fabrication
09-10-2012 08:36 PM
hondacrxhf_3
06-07-2005 06:33 PM
hondaeg8
05-01-2005 12:15 AM
91hatchcivic
05-09-2004 08:49 AM
Quick Reply: h22a1 h22a4 crankshaft difference.
