h22a swap....are these two parts the same?
Old 12-11-2010, 10:19 PM
holmesnmanny's Avatar
Default h22a swap....are these two parts the same?
I'm having a problem sourcing a bypass control valve solenoid for my swap, I was looking at my air cleaner assembly and saw that the intake control solenoid valve looks almost exactly the same using the same connector. Will I be able to use the accord intake control solenoid valve on the vacuum tank in place of the bypass control valve solenoid for the swap? I'm pretty sure I can find a bunch of those.
http://www.hondaautomotiveparts.com/...y5=AIR+CLEANER
part #39
http://www.hondaautomotiveparts.com/...TUBING+%282%29
part #11
thanks in advance
Old 12-12-2010, 05:43 PM
Acidcrakker's Avatar
Default Re: h22a swap....are these two parts the same?
They probally are the same, but I think that you will be the first one I know to actually use one in anything. Most people even without swaping throw it in the trash and dont use it.
holmesnmanny
12-14-2010 03:21 PM
ketchup
11-15-2009 06:13 PM
Quick Reply: h22a swap....are these two parts the same?
