H22a..need to borrow a P13 for 10 minutes Santa rosa CA area
I have an H22a 93 civic with code #12. I just moved from Ohio to California and have been buying parts to get it inspected and smogged. I went threw the troubleshooting process 3 times for #12 code..EGR system malfunction. I bought an EGR valve today and will double check that, but everytime I troubleshoot I end up at the part where it says check ECU or replace. So I would appreciate someone hooking me up with a P13 for 93 H22a so I can double check that also.
10 bucks for the sharee.
~Chris
~Chris
Re: H22a..need to borrow a P13 for 10 minutes Santa rosa CA area
I am in AZ but I can let you borrow it for a bit via mail... but it might be easier if you find somebody there local- let me know
So I replaced the EGR valve on my H22a and #12 code is permanently gone. Now #43 came back which is fuel supply malfunction and o2 sensor. I have gone through the troubleshooting process for # 43 now 3 times also and I have the results again..replace ECM..UGH
Anyone else interested in loaning me a moment to check my code? I only need 10 minutes time using another working P13 for 92-96 H22.
Thanks Bk8 I don't know if I can afford the collateral. I'll ask a few people and hope I get lucky. This is a pain in my butt.
BUMP for borrowing a usdm p13
Are there any honda meets in the Santa Rosa vicinity?
yesir I need OBD1 USDM ECU for H22a. I don't have $100 bucks to sacrifice though. Would you agree to loaning me the ecu for shipping plus 20 dollars. Give me your terms. I'm still working on the problem so I might wait on the ecu idea.
~Chris ~
~Chris ~
