h22a head bolt torque specs
Old 11-02-2004, 11:45 AM
rev-speed's Avatar
Default h22a head bolt torque specs
quick help
someone i need the torque specs 4 torqueing down a h22a head
thats head bolts
cam tower
thanks
Old 11-02-2004, 12:28 PM
98TypeSH's Avatar
Default Re: h22a head bolt torque specs (4cylinder)
tighten in sequence 3 steps.
1st 29 ft lbs
2nd 51 ft lbs
3rd 72.3 ft lbs
be sure to put fresh oil on the threads and under the bolt heads. If a bolt makes any noise while torquing, loosen it and go from step 1.
EDIT: Thats for the head bolts BTW.
Modified by 98TypeSH at 2:16 PM 11/2/2004
Old 11-02-2004, 02:50 PM
LudeyKrus's Avatar
I'm pretty sure the specs posted above are for ARP head studs. The H22 stock headbolts are torqued down at 27 and 54 ft/lb's, IIRC off the top of my head.
Old 11-02-2004, 03:02 PM
john d
Guest
Posts: n/a
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure the specs posted above are for ARP head studs. The H22 stock headbolts are torqued down at 27 and 54 ft/lb's, IIRC off the top of my head.</TD></TR></TABLE>
yeah thats what i did for my arp's but instead of 72 ft lbs on my last one i tq'd it to 81ft lbs, what headstuds do you have stock or arp's?
Old 11-02-2004, 03:19 PM
rev-speed's Avatar
stock
pleej
08-13-2015 02:37 PM
KB91Hatch
07-20-2009 09:51 PM
Varano44
06-27-2008 08:55 PM
lsvtec101
06-27-2005 05:13 PM
Quick Reply: h22a head bolt torque specs
