H22 timing belt tension
Old 06-20-2003, 04:43 AM
petrv's Avatar
Default H22 timing belt tension
I have installed the timing belt and timing balancer belt and the tension of the balancer belt seems to me very poor (compared to the timing belt tension). Is this right? I dont want to destroy my engine...
Old 06-20-2003, 04:55 AM
Quade's Avatar
yes that's correct. It seems too slack but that's the way it is installed. Once u're sure the spring tensioner is good.
Old 06-20-2003, 05:02 AM
petrv's Avatar
Default Re: (Quade)
Thanks for info. It really seems to be very slack, that I can push it by hand very easily.
Old 06-20-2003, 11:54 AM
New User
F120man's Avatar
Default Re: H22 timing belt tension (petrv)
of the oil leaks out of the belt tensioner, is it really bad? caus eive replaced my water pumkp and timing belt, and the belt tensioner was a bitch to install back cause it wouldnt go back down. so i used a zippy tie and kinda forced it down. is this right?
Old 06-20-2003, 12:17 PM
2point6's Avatar
Default Re: H22 timing belt tension (F120man)
forcing it can break the 1 way spring. There is a special clamp that is used to hold the tensioner while it is compressed.
Old 06-20-2003, 12:23 PM
Jonathan_ED3's Avatar
Default Re: H22 timing belt tension (2point6)
Yeah, Honda supplies it when you buy a new tensioner.
The $50 I spent on a new one for myself is well worth the peace of mind it gave me after trying to install it with the old one...the new one is much more taught than the old one with both at full lock.
3s1k
09-27-2010 01:58 PM
grngsr01
03-14-2005 05:19 AM
soHybridized
03-02-2005 08:45 PM
SilverEk3dr
01-29-2003 11:27 AM
Quick Reply: H22 timing belt tension
