Gutted cat convertor or Test pipe?
California has some strict *** smog laws, so i'm running a gutted cat convertor because my cat failed. I heard I can actually lose power and whatnot from a gutted cat convertor. What are your recommendations? I'm running DC headers, aem intake, and a greddy sp2. All bolt-ons.
I have extra greddy 2.5" piping that I can have a shop cut and drill holes to make a test pipe, what do you think would be best?
Re: Gutted cat convertor or Test pipe? (brandobot89)
in ur place i would keep the cat without gutting it and spend 20-30 bucks on test pipe so when ur smog comes up, u wont have to buy another cat, hope u havent gutted yet, aldo u said ur running it already. Gutted cat is same thing as test pipe.
Re: Gutted cat convertor or Test pipe? (russlan44)
Its gutted already. The cat convertor failed, check engine light came on and it began to rattle. So i removed it and bashed everything out and put it back in. I got a o2 sensor spacer and the CEL is gone.
But im thinking about getting a test pipe, I keep reading gutted stock cat convertor can slow your car down.
gutted cat doesn't slow you down, it does makes more noise though. you should see your engine revving a lil quicker. slap a good cat-back exhaust on and it will rev like crazy. but you will need new cat for smog test = $350 from dealership
I'd go for the gutted cat since they can also do a visual inspection to see if there is a cat present underneath the car. The flow difference between a gutted cat and a test pipe is minimal at best, especially at the level of mods you're at.
My cat also failed and I gutted it. Killed performance obviously. Replaced it with a universal Carsound highflow cat for $55, but I'm not in Cali.
straight through resonators is the best way to go, and get a po box address on your license from outside county that doesnt have smog testing.
Problem solved.
Problem solved.
I read somewhere that test pipe pollutes the world in which we live in and also makes 1 more horsepower compared to hi-flow and hi-flow does not contaminate mother nature as much. This is a suggestion get a magnaflow or carsound hi-flow and also at the same time buy a normal new california cat. This way when you have to do a smog check just unbolt and put in the new california cat. and once your done unbolt that and put on the hi-flow. This is all just bolt-ons, not welds.
thaiboiz
11
04-03-2008 05:55 PM
DCSportEJ1Civic
26
07-16-2007 12:44 PM
