Grinding noise coming from driver's side rear wheel
I just put on some 17's on my 4th gen Prelude. There's a grinding noise coming from my driver's side rear wheel. None of the other wheels make this grinding noise. Does anybody know what the wheel can be grinding against? The wheel size is 17x7...
Re: Grinding noise coming from driver's side rear wheel (dtec)
when ur going down the street at 30mph. get out, run after it and check.
but anyways check around the tire first, might be some plastic
You might want to check your brake pads to make sure their not rubbin or too low. I had the same problem on my drivers right front wheel i changed pads cause i needed them anyways and solved the problem. I dun think you have to change your pads but i would check it, maybe even take it off put it back on and see if that works. they maybe unbalanced too
carbonlaced
06-27-2006 10:02 AM
