Venting block from BS alignment hole.
Old 07-14-2015, 04:31 PM
ojasia's Avatar
Default Venting block from BS alignment hole.
I was wondering if it is a good/possible idea to setup a block ventilation from the balance shaft alignment hole. I have the KS BS delete full kit installed and no spray bar. My Oil pressure is like more then great, but I have no bottom end ventilation. Idk anywhere else to go from. Its just a built H22 NA and I'm running PCV for the top end. Idea's? Concerns?
When I first got my built block in and started I actually realized I had forgot to re-install the bolt from my old block to new, when I saw the leaking on first start, small puddle nothing big. But would this be to low of a spot to put one? and being in the back of the block accelerating maybe oil would sag to the back and go into it anyways. Thought's?
I'm not worried about it being that its a NA build, but I like to learn and do new stuff/projects, and if it helps then why not. Thanks.
Old 07-14-2015, 06:13 PM
moderator emeritus
98vtec's Avatar
Default Re: Venting block from BS alignment hole.
Most people use the valve cover for venting crankcase pressure
Old 07-15-2015, 05:04 AM
ojasia's Avatar
I thought the VC only vented the top end. Good to kno. Thnx.
Old 07-15-2015, 05:07 AM
moderator emeritus
98vtec's Avatar
The top and bottom are connected via oil drains
Old 07-15-2015, 12:46 PM
ojasia's Avatar
Lol and voila! I feel stupid. . . 98vtec thats why you get paid the big bucks.
kenneth4g4d
05-31-2014 04:25 AM
aleEvo
12-30-2012 10:22 PM
dunkd
01-24-2010 09:02 AM
shingles
10-22-2002 08:25 PM
Quick Reply: Venting block from BS alignment hole.
