Frying ignition coils like its my job....
#28
Re: (mgags7)
well the datalogged # should be total timing correct? if so you need to verify that with a timing light to make sure that its the same as what the computer thinks it is.
#29
Re: (Rosko)
The way I see it is that there are two ways the timing could've been setup...
1.) distributor was synced to what the computer was outputting, done by rotating the distributor to get the correct timing reading, or by an electronic offset like aem uses. This would be the same way you setup timing on a stock motor (rotating distributor).
Or..
2.) the distributor was bolted to the head in the "retarded position" rotated counterclockwise, and was made up for by an overly advanced base ignition map, so even if the map says 44 advanced it could still be putting out 30ish or whatever.
Or..
#30
moderator emeritus
Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">when i datalog do i need to subtract base timing from the datalogged #??</TD></TR></TABLE>
that makes it sound more realistic. base timing is ~15* so 44* minus 15* = 29*
#32
Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko »</TD></TR><TR><TD CLASS="quote">The way I see it is that there are two ways the timing could've been setup...
Or..
2.) the distributor was bolted to the head in the "retarded position" rotated counterclockwise, and was made up for by an overly advanced base ignition map, so even if the map says 44 advanced it could still be putting out 30ish or whatever.</TD></TR></TABLE>
base timing was set with a timing light to the flywheel at the stock spec, 15*
Or..
d16rice
12
04-03-2005 06:09 PM
