looking for h22 turbo log manifold dyno numbers
looking for h22 turbo log manifold dyno numbers and manufacturer.
We all know log manifolds are restrictive. The point of this is not to see who makes the best log manifold but to see if log manifolds are too restrictive for the h-series motors and if they create any backpressure that could cause an issue.
Looking for stock and built motor results.
Please post:
1) how much whp
2) how much boost you are running
3) what brand log manifold you are using (not as important but helps)
4) stock or built motor
5) any issues you may have run into.
I know different turbo's will produce different numbers but i'm just looking to see if log manifolds can handle the power, so the turbo isn't as important, but you can list that also if you'd like.
Please post:
1) how much whp
Re: looking for h22 turbo log manifold dyno numbers (oranginal)
log manifolds can make good power. steve oaks got 600+ whp with a log manifold. i believe it was a peak boost but i could be way wrong.
dellas
21
08-21-2013 01:18 AM
oranginal
03-21-2010 11:57 AM
