F23 rods - Honda-Tech
F23 rods
Old 04-18-2011, 04:33 PM   #1
4.8t's Avatar
Default F23 rods
Who makes them beside Crower? Are they the only ones? Im going to build a f23 since my h22 has a huge hole in the side of it.
4.8t is offline   Reply With Quote
Old 04-19-2011, 12:00 PM   #2
4.8t's Avatar
Default Re: F23 rods
Sounds like it would be the same price then. Might as well go with who already has the specs then huh.
Old 04-19-2011, 01:27 PM   #3
Can he use K20 rods? The only difference I can see is that they are 2 mm shorter that F23 rods, which could be good if he's using high compression, domed pistons.
Lil Tones is offline   Reply With Quote
Old 04-19-2011, 02:37 PM   #4
4.8t's Avatar
That would make the already bad Rod stroke ratio worse lol. And I'm going with flat top k20 wiseco pistons. And I want rods that can take 8000 rpm with that long stroke. 10.3:1 compression is fine for me.
Old 04-19-2011, 04:12 PM   #5
4.8t's Avatar
they are 316 according to wiseco. that's for .5mm overbore.
I don't know if that includes pins and rings or not.
Old 04-20-2011, 01:06 AM   #6
4.8t's Avatar
i want better rods anyway. not trying to cheap out, just wanted to know if there were any lower priced aftermarket rods available. i plan on working this motor pretty good. nothing spectacular, i just want an honest 400whp when its all said and done with my old turbo off my truck. its a t04r that i swaped housings to be a t3/t04r. i figure 15-20psi should get me where i want to be. it will be water/meth injected so i'm not worried about 10:1 compression being too much.
Old 04-20-2011, 11:58 AM   #7
4.8t's Avatar
But that tiny bore. From 87 h22 to 85 f22. Will that not cause horrible valve shrouding? What can you bore it to? 85.5? I was going 86.5 on the f23 so atleast it would have close to stock bore size for the head. Just wondering here but do they not turbo the k20 motors? Do they do ok with big power and skinny rod bearings? I haven't looked it to it, that's an honest question.
Old 04-20-2011, 01:50 PM   #8
4.8t's Avatar
An f22 would be easy to find. Junk yard down the road is full of them. How strong is the girdle on it? I thought the f23 had bigger mains and the stronger girdle. That long stroke is so tempting though. So many decisions. What's the real down side of the slightly smaller bearing when considering the rod is aftermarket and good oil pressure.
Old 04-20-2011, 03:16 PM   #9
4.8t's Avatar
I don't have alot of funds for the build. So offset grinding the f22 crank and custom rods are a bit out of my range at the moment. This motor will be a daily driver 40+ miles a day. It won't always see 8000 rpm unless spirited driving is required. My tahoe will see more track time than my car. With my h22 I hardly went over 3500 rpm. Just didn't need it. Lol. Honestly my wife b18 build will get the turbo before me. If I can get enough power and torque with cams and head job it will probably stay that way for awhile. I wouldn't think 235-250hp is too bad of a n/a goal. Is it?
Old 04-21-2011, 01:42 PM   #10
4.8t's Avatar
Turns out the number one rod broke and put a hole in the motor and the number two rod bent. Head looks ok from what I can see.
Old 05-04-2011, 12:29 PM   #11
Are H23 and F23 rods the interchangeable?
Turbo3GLude is offline   Reply With Quote
Old 05-04-2011, 11:10 PM   #12
gstrudler's Avatar
No, h23 and f22 rods are I believe.
gstrudler is offline   Reply With Quote
1992 accord with f23a4 engine Yere# Honda Accord (1990 - 2002) 1 05-23-2016 05:26 AM
Honda F23A JPN vs F23A1 USD Engine Performance Hondadude65 Honda Accord (1990 - 2002) 1 03-13-2015 01:14 AM
crank question cjmurillo Honda Accord (1990 - 2002) 1 11-05-2008 05:50 PM
D15 to F23 swap kimmiey Hybrid / Engine Swaps 0 04-29-2007 08:23 AM
Tags
87mm, boring, compression, diesel, drivetrain, f22, f22b, f23, high, honda, k20, ls6, pistons, rods, run, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
