Starting issues i need help asap!!!
Old 01-05-2006, 01:01 PM
Rudelude22's Avatar
Default Starting issues i need help asap!!!
I have searched already!! Its a 92 si chassis with a jdm h22a in it. Well i have spark,fuel and compression and its still not doing anything, ive already changed out the ICM, dizzy, cap, rotor and plugs...ive checked the timing its good. what could it be? I heard that the main relay in these cars go bad could that be a cause? any input would be awesome! thanks alot.
Old 01-05-2006, 01:41 PM
IHateJDM's Avatar
Default Re: Starting issues i need help asap!!! (Rudelude22)
are you sure your timing is right? what year h22? if 4th gen, did you add a resistor box for the injectors?
Old 01-05-2006, 01:57 PM
Rudaluda's Avatar
its a jdm h22 so im not sure what year but it is obd1 and my car is a 92 prelude and was already wired up with a resistor box.
Old 01-05-2006, 02:02 PM
killer hatch's Avatar
is it turning over? i had problems like this befor. make sure all the grounds are in place.
Old 01-05-2006, 04:59 PM
Rudaluda's Avatar
some on po.com said it might be the main relay, any exp. this problem be4 and where exactly is it.
Old 01-05-2006, 10:08 PM
Rudaluda's Avatar
bump
Old 01-05-2006, 10:46 PM
i_kick_turtles's Avatar
Default Re: (Rudaluda)
You should check your timing again. As for the main relay i'm not sure in a Prelude, but check to either the right or left of the steering wheel.
Old 01-06-2006, 05:14 AM
IHateJDM's Avatar
Default Re: (I R Tylor)
the main relay keeps your fuel pump from priming, and you said you had fuel in your first post. How do you know you have fuel and spark?
Old 01-06-2006, 08:37 AM
SpeedFreak77's Avatar
Default Re: (IHateJDM)
You may want to go out and get a second set of spark plugs or clean the one's you have in and then have someone try starting the car while you turn the distributor. I thought I had my timing right on and the car wouldn't fire up and built up a lot of carbon on the plugs. Swapped them out (and cleaned the first set to have for a back up) and had my GF try starting it while I moved the distributor and it fired right up.
Hey it may not be the correct way of doing it but it fired up and I got the timing set dead on.
I am sure with the experience foating around here there may be some better advice but it's what I did.
Old 01-06-2006, 08:51 AM
Rudaluda's Avatar
^^^speedfreak77 i tried exactly what you had descirbed. I know i have fuel because my fuel pressure gauge on my rail is showing pressure when i try to turn the key, secondly i took out every plug 1 by 1 put it agaist the header and it got spark. im stumped i have no idea.
Old 01-06-2006, 08:59 AM
It sounds like the injectors may not be working correctly. Maybe like IHateJDM said it's a problem with the resistor box.
HMMMMMMMMMMMMMMMMMMMMMM?????????
Old 01-06-2006, 01:07 PM
Just because your getting fuel to the rail doesn't mean you're getting it to the cylinders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like the injectors may not be working correctly. Maybe like IHateJDM said it's a problem with the resistor box.
Old 01-06-2006, 08:10 PM
delirious1520's Avatar
hey bro i just had this exact problem check the crank positioning sensor by the dizzy i had spark and fuel and thought it was timing but it was cps but just dbl check your firing order too 1-3-4-2 1 being by the dizzy hit me back
Old 01-06-2006, 11:24 PM
The Phil's Avatar
Is it turning over at all?
Make sure your starter is working before you start pulling crap apart like this
Old 01-07-2006, 06:50 AM
Rudaluda's Avatar
yeah the starter will turn the engine over. As for the Crank sensor wouldnt i get a code where is it located?
IMPORTMyth01
02-08-2008 08:16 PM
zCivic
12-15-2005 08:00 AM
rocaveli
33
07-13-2005 03:16 PM
Phaze1_Ls
10
10-02-2003 03:48 PM
webnit
10-08-2002 12:41 PM
Quick Reply: Starting issues i need help asap!!!
