f22a non vtec swap question
Old 02-09-2007, 03:14 PM
zenon8890's Avatar
Default f22a non vtec swap question
hi, i swapped a sohc f22a into my 1995accord, it used to have f20 sohc non vtec. its runs nice but the ecu i have doesnt have a code or the sticker is gone, what is the code for my ecu?! and will it run better if i used a vtec d15b p08 ecu?!
Old 02-09-2007, 04:00 PM
pinecone's Avatar
Default Re: f22a non vtec swap question (zenon8890)
You swapped a vtec F22a? Is it an F22a1? If so its not vtec. Don't use the D15b ecu, will not run it right at all. Also if you are using the stock ecu that was in the car, it wouldn't control vtec anyway.
Old 02-09-2007, 07:15 PM
zenon8890's Avatar
its not a vtec engine, i said non vtec, i'm running the car on the old f20 ecu
Old 02-10-2007, 05:21 AM
pinecone's Avatar
Default Re: (zenon8890)
You can use the ecu the car came with. Both motors are OBD1 so you won't have any problems. I am about to swap a broke f22a1 for a F20a and it will drop right in.
Dave Brabant
06-28-2018 01:17 PM
heflin94eg
Engine Management and Tuning
12-04-2012 05:19 PM
integra3586
10-15-2007 03:22 AM
DOHC-V-TEC-DA
02-03-2006 06:03 PM
tr4il
11-25-2001 11:38 AM
Quick Reply: f22a non vtec swap question
