F20b piston and rod compatibility - Honda-Tech
Old 03-07-2017, 02:38 AM   #1
Default F20b piston and rod compatibility
I have an f20b in my honda prelude and i need to know which rods and pistons are good thanks for the help
manueel423 is offline   Reply With Quote
Old 03-07-2017, 02:45 AM   #2
Default Re: F20b piston and rod compatibility
aftermarket, oem? for what purpose?
TimiK is offline   Reply With Quote
Old 03-07-2017, 01:11 PM   #3
Quote:
like h series or other f series engines etc
Old 03-07-2017, 08:49 PM   #4
oem or aftermarket?
you want to raise your compression or what?
Quote:
Originally Posted by JDogg View Post
there is nothing off the shelf for that engine, everything will have to be custom made.
easiest thing is to use h22a4 crank, h22 rods and custom pistons.
bisimoto has f20b rods but theyre 500, for pistons maybe K20A? dont know which rods you would need with em
theres nothing for f20b directly so you gotta be creative and do research
Old 03-09-2017, 07:19 AM   #5
Last I checked bisi didn't carry the rods anymore since he's pretty much done with Hondas. OP, you may be able to call and get a one-off set made if he still has the specs.
For the most part there are no direct replacement forged components for the F20B. There are solutions to that problem and this issue has been discussed many times over. Search.
Aradin is offline   Reply With Quote
f22 all motor f22 killer All Motor / Naturally Aspirated 42 02-05-2012 01:48 PM
h22 crank in F20B??? 96ekdowork Honda Prelude 7 08-01-2011 06:51 AM
F20B internals? RudeLude Forced Induction 6 02-17-2009 03:23 AM
rods n pistons Laojoeturbo Want to Buy 3 01-27-2009 10:54 PM
h23 block and f22 block!!! b20accord For Sale 2 03-29-2007 03:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
